this bug's URL: http://intevation.de/rt/webrt?serial_num=5008
Subject: r.neighbors: add null pass-through support
transferred here from #2398 due to spam bombing
Sun, May 9 2004 14:14:53 Request created by guest
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
GRASS Version: CVS April 2004
r.neighbors should have an option so output maps only contain data where data
exists in the original map.
Currently output maps 'grow' to the search distance, i.e.
output_val=mean(nonNULL(cell_values))
Maybe for completeness/correctness it should have an option to return a value
of null when there is ANY null data as part of the calculation, shrinking the
map at the region bounds and around any null cells, as mathematically the
neighborhood
analysis is only 100% valid in these areas. (-s strict?)
see 'r.series -n'
thanks,
Hamish
