this bug's URL: http://intevation.de/rt/webrt?serial_num=5025
Subject: v.hull: empty if statement
grass obtained from: CVS
compiling v.hull, I discovered:
[neteler@dandre v.hull]$ make
main.c: In function ‘loadSiteCoordinates’:
main.c:141: warning: empty body in an if-statement
if ((pointIdx % ALLOC_CHUNK) == 0);
*points = (struct Point *) G_realloc(*points, (pointIdx + ALLOC_CHUNK) * sizeof(struct Point));
I don't know how to fix this.
Remove the semicolon; the above will be parsed as:
A semicolon on its own is a valid statement which does nothing, hence
the "empty body" warning.
I've fixed this in CVS.
