Hamish wrote:
> > this bug's URL: http://intevation.de/rt/webrt?serial_num=5037
> > Subject: GRASS 6.3: d.graph segfault
> > d.graph segfaults on startup. (GRASS 6.3-cvs only)
Glynn:
> It segfaults because trans is NULL, because R_RGB_color()
> is called before R_open_driver().
> R_open_driver() or R__open_quiet() must be called before almost any
> other R_* functions are called. The only exceptions are:
> R_parse_monitorcap
> R_set_update_function
> R_call_update_function
> R_has_update_function
> R_set_cancel
> R_get_cancel
> R_pad_freelist
> R_pad_perror
> The old library would silently ignore any operations performed while
> not connected to a driver.
There's another problem, G_str_to_color() [lib/gis/color_str.c] returns
an error if a color is given as a R:G:B triplet.
Same program, but a completely unrelated bug.
It seems to work fine with triplets from other modules (d.vect).
e.g.:
G63> echo "symbol basic/box 16 50 50 green 50:50:50" | d.graph
WARNING: [50:50:50]: No such color
sscanf() fills red,green,blue with garbage? [which fails >255 test]
ret = sscanf (buf, "%d%[,:; ]%d%[,:; ]%d", red, temp, green, temp, blue);
I'm having no luck debugging this. R,G,B getting cast to another type
somehwhere???
lib/gis/color_str.c:54:
int G_str_to_color (const char *str, int *red, int *green, int *blue)
include/gis.h:299:
typedef struct
unsigned char r, g, b, a; /* red, green, blue, and alpha */
} RGBA_Color ;
display/d.graph/do_graph.c:386:
ret = G_str_to_color(line_color_str, &line_color->r, &line_color->g, &line_color->b);
IOW, do_graph.c is passing pointers to "unsigned char" fields while
G_str_to_color() expects pointers to "int"s, resulting in the pointer
targets overlapping (each is 4 bytes wide, but they start 1 byte
apart). The value of *red will be the result of reading the entire
structure as if it was an int.
On a little-endian system, the value will be 0xAABBGGRR (the alpha
field will typically contain garbage); on a big-endian system, it
would be 0xRRGGBBAA. However, the most common big-endian architecture
(PPC) requires "int"s to be aligned, so you would get an exception
(SIGBUS, IIRC) trying to read or write *green or *blue.
The d.graph code needs to be changed to e.g:
int r, g, b;
ret = G_str_to_color(line_color_str, &r, &g, &b);
line_color->r = (unsigned char) r;
line_color->g = (unsigned char) g;
line_color->b = (unsigned char) b;
