this bug's URL: http://intevation.de/rt/webrt?serial_num=5072
Subject: d.text.freetype does not print accented characters
Platform: GNU/Linux/x86
grass obtained from: CVS
GRASS Version: cvs_head_20060829
Using accented characters in d.text.freetype fails for me.
From the first accented character onward, nothing is displayed, i.e
d.text.freetype -n text="Densité de la population" east_north=2,95 size=3 col=black path=/usr/share/fonts/truetype/ttf-bitstream-vera/Vera.ttf
displays
Densit
This is on Debian testing, with libfreetype6 2.2.1
Moritz
displays
Densit
There is a bug in the built-in ISO-8859-1 -> UCS-4 decoder, which is
only used if iconv() isn't detected.
--- display/d.text.freetype/main.c 30 Aug 2006 02:00:46 -0000 2.11
+++ display/d.text.freetype/main.c 30 Aug 2006 16:14:49 -0000
@@ -799,10 +799,10 @@
p2 = *out;
for(i = 0; i <= l; i++)
- p2[2*i+0] = 0;
- p2[2*i+1] = 0;
- p2[2*i+2] = 0;
- p2[2*i+3] = text[i];
+ p2[4*i+0] = 0;
+ p2[4*i+1] = 0;
+ p2[4*i+2] = 0;
+ p2[4*i+3] = text[i];
ol = l * 4;
#endif
Note that d.text.freetype requires iconv in order to use encodings
other than ISO-8859-1.
If your version of d.text.freetype was built to use iconv, then I
don't know what the problem is.
