[GRASS-dev] [bug #5076] (grass) gis.m: freeze when zooming on Map Display 2 while Map Display 1 is being refreshed
michael.barton@asu.edu wrote (Wed, Aug 30 2006 18:50:06):
I just added error trapping for trying to re-render 2 maps simultaneously.
What happens now is that the slower-rendering map just doesn't get rendered
and you have to click the render button again.
I'm affraid it's still not fully fixed. Another error is issued now for the
same case:
bad window path name ".help_shell"
    while executing
"winfo reqwidth $_top"
    (procedure "DynamicHelp::_show_help" line 22)
    invoked from within
"DynamicHelp::_show_help .mapcan(1).mf.topf.tb0.zoomin 177 67"
    ("after" script)
And when I try to refresh display on Map Display 2 after this error, I get
another error:
couldn't open "15123.4.ppm": no such file or directory
    while executing
"image create photo mapimg.$mon -file "$outfile($mon)""
    (procedure "MapCanvas::composite" line 20)
    invoked from within
"MapCanvas::composite $mon"
    (procedure "MapCanvas::drawmap" line 40)
    invoked from within
"MapCanvas::drawmap $mon"
    (procedure "MapCanvas::display_server" line 9)
    invoked from within
    ("after" script)
Refreshing the Map Display 2 the second time doesn't trigger any action...
But luckily gis.m doesn't freeze anymore now :).
Maciek
