[GRASS-dev] [bug #5089] (grass) complete text file
this bug's URL: http://intevation.de/rt/webrt?serial_num=5089
------=_Part_96603_15034519.1157281527913
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Content-Transfer-Encoding: 7bit
Content-Disposition: inline
Here is the complete text file:
Subject: gis.m & = error; d.m & = O.K.
Platform: GNU/Linux/x86_64
grass obtained from: Trento Italy site
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: grass 6.3
Please enter your name and error description here. Don't
write general statements
such as "this could be better" - please explain in
details how a certain problem can be solved or a feature be
added/improved. Send
different report for different problems. Thanks!
Welcome to GRASS 6.3.cvs (2006)
GRASS homepage:
http://grass.itc.it/
This version running thru: Bash Shell
(/bin/bash)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
Start the graphical user interface with: gis.m &
When ready to quit enter: exit
GRASS 6.3.cvs (d2133):/home/md/grass > gis.m &
[1] 20263
PROJ_INFO file not found for location d2133
    while executing
"close $input"
    (procedure "MapCanvas::runprograms" line 37)
    invoked from within
"MapCanvas::runprograms $mon [expr {$mymodified != 0}]"
    (procedure "MapCanvas::drawmap" line 38)
    invoked from within
"MapCanvas::drawmap $mon"
    (procedure "MapCanvas::display_server" line 9)
    invoked from within
    ("after" script)
THE SAME ERROR MESSAGE FOR MY OTHER LOCATONS
GRASS homepage:
(/bin/bash)
[1] 20263
    while executing
"close $input"
    invoked from within
    invoked from within
    invoked from within
    ("after" script)
GRASS homepage: http://grass.itc.it/
This version running thru: Bash Shell (/bin/bash)
GRASS 6.3.cvs
(spearfish60):/home/md/grass-data/spearfish60/PERMANENT/vector >
gis.m
[1] 2744
GRASS 6.3.cvs
d.mon
start=gism
PNG: GRASS_TRUECOLOR status: FALSE
PNG: collecting to file: map.png,
     GRASS_WIDTH=640, GRASS_HEIGHT=480
Graphics driver [gism] started
[1]+ Done gis.m
GRASS 6.3.cvs
d.vect map=roads
GRASS 6.3.cvs
NO ERRORS, NO RESULTS
Jonas Mockus
e-mail:
jmockus@gmail.com
Content-Type: text/html; charset=ISO-8859-1
Here is the complete text file:<br>&nbsp;******************************************************************************************<br>Subject: gis.m &amp; = error; d.m &amp; = O.K. <br><br>Platform: GNU/Linux/x86_64<br>grass obtained from: Trento Italy site
<br>grass binary for platform: Downloaded precompiled Binaries<br>GRASS Version: grass 6.3<br><br>Please enter your name and error description here. Don't <br>write general statements<br>such as &quot;this could be better&quot; - please explain in
<br>details how a certain problem can be solved or a feature be <br>added/improved. Send<br>different report for different problems. Thanks!<br><br>Welcome to GRASS 6.3.cvs (2006)<br>GRASS homepage:<br><a href="http://grass.itc.it/&quot;&gt;
http://grass.itc.it/&lt;/a&gt;&lt;br&gt;This version running thru:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Bash Shell<br>(/bin/bash)<br>Help is available with the command:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; g.manual -i<br>See the licence terms with:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; g.version -c<br>Start the graphical user interface with:
gis.m &amp;<br>When ready to quit enter:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; exit<br>GRASS 6.3.cvs (d2133):/home/md/grass &gt; gis.m &amp;<br>[1] 20263<br>GRASS 6.3.cvs (d2133):/home/md/grass &gt;<br><br><br>PROJ_INFO file not found for location d2133
<br>PROJ_INFO file not found for location d2133<br>&nbsp;&nbsp;&nbsp; while executing<br>&quot;close $input&quot;<br>&nbsp;&nbsp;&nbsp; (procedure &quot;MapCanvas::runprograms&quot; line 37)<br>&nbsp;&nbsp;&nbsp; invoked from within<br>&quot;MapCanvas::runprograms $mon [expr {$mymodified != 0}]&quot;
<br>&nbsp;&nbsp;&nbsp; (procedure &quot;MapCanvas::drawmap&quot; line 38)<br>&nbsp;&nbsp;&nbsp; invoked from within<br>&quot;MapCanvas::drawmap $mon&quot;<br>&nbsp;&nbsp;&nbsp; (procedure &quot;MapCanvas::display_server&quot; line 9)<br>&nbsp;&nbsp;&nbsp; invoked from within<br>&quot;MapCanvas::display_server&quot;
<br>&nbsp;&nbsp;&nbsp; (&quot;after&quot; script)<br><br>THE SAME ERROR MESSAGE FOR MY OTHER&nbsp; LOCATONS<br><br>***********************************************************<br>Welcome to GRASS 6.3.cvs (2006)<br>GRASS homepage:<br><a href="http://grass.itc.it/&quot;&gt;
<br>&nbsp;&nbsp;&nbsp; (&quot;after&quot; script)<br><br>********************************************************************<br><br>Welcome to GRASS 6.3.cvs (2006)<br>GRASS homepage:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; <a href="http://grass.itc.it/&quot;&gt;
http://grass.itc.it/&lt;/a&gt;&lt;br&gt;This version running thru:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Bash Shell (/bin/bash)<br>Help is available with the command:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; g.manual -i<br>See the licence terms with:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; g.version -c<br>Start the graphical user interface with:
gis.m &amp;<br>When ready to quit enter:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; exit<br>GRASS 6.3.cvs<br>(spearfish60):/home/md/grass-data/spearfish60/PERMANENT/vector &gt; <br>gis.m<br>&amp;<br>[1] 2744<br>GRASS 6.3.cvs<br>(spearfish60):/home/md/grass-data/spearfish60/PERMANENT/vector &gt;
<br>d.mon<br>start=gism<br>PNG: GRASS_TRUECOLOR status: FALSE<br>PNG: collecting to file: map.png,<br>&nbsp;&nbsp;&nbsp;&nbsp; GRASS_WIDTH=640, GRASS_HEIGHT=480<br>Graphics driver [gism] started<br>[1]+&nbsp; Done&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; gis.m<br>GRASS
6.3.cvs<br>(spearfish60):/home/md/grass-data/spearfish60/PERMANENT/vector &gt;<br>d.vect map=roads<br>GRASS 6.3.cvs<br>(spearfish60):/home/md/grass-data/spearfish60/PERMANENT/vector &gt;<br><br clear="all">NO ERRORS, NO RESULTS
<br>-- <br>Jonas Mockus<br>e-mail:<br><a href="mailto:jmockus@gmail.com">jmockus@gmail.com</a>
------=_Part_96603_15034519.1157281527913--
--- Headers Follow ---
From jmockus@gmail.com Sun Sep 3 13:05:30 2006
Return-Path: <jmockus@gmail.com>
Delivered-To: grass-bugs@lists.intevation.de
Received: from kolab.intevation.de (aktaia [212.95.126.10])
  by lists.intevation.de (Postfix) with ESMTP id 48C0E1005DB
  for <grass-bugs@lists.intevation.de>; Sun, 3 Sep 2006 13:05:30 +0200 (CEST)
Received: from localhost (localhost.localdomain [127.0.0.1])
  by kolab.intevation.de (Postfix) with ESMTP id 32BB2111F4E
  by kolab.intevation.de (Postfix) with ESMTP id 1C46B140427
Received: from wx-out-0506.google.com (wx-out-0506.google.com [66.249.82.239])
  by kolab.intevation.de (Postfix) with ESMTP id 398AB111F4E
  for <grass-bugs@intevation.de>; Sun, 3 Sep 2006 13:05:28 +0200 (CEST)
Received: by wx-out-0506.google.com with SMTP id t15so1521085wxc
        for <grass-bugs@intevation.de>; Sun, 03 Sep 2006 04:05:28 -0700 (PDT)
DomainKey-Signature: a=rsa-sha1; q=dns; c=nofws;
        s=beta; d=gmail.com;
        h=received:message-id:date:from:to:subject:mime-version:content-type;
        b=cECDdAzl/DILCufVc6yXNPF/zqcdC9Qe68BuvU7VyjHlqxyqno5u2wvsJULmNHTPd3GYfG57m40/xKFTj38QdPdjB9UfNtV8aMzINQxEvtYAYArmN3EaKZE1meX4r876F9iSKVXYkGonoXZ/0f0Nm+H3wFKkUBElMfwaf7woXG4=
Received: by 10.70.118.4 with SMTP id q4mr3497129wxc;
        Sun, 03 Sep 2006 04:05:27 -0700 (PDT)
Received: by 10.70.11.18 with HTTP; Sun, 3 Sep 2006 04:05:27 -0700 (PDT)
Message-ID: <9140b6030609030405v6cdf48ddt37afc5f2c11326d@mail.gmail.com>
Date: Sun, 3 Sep 2006 14:05:27 +0300
To: "Maciek Sieczka via RT" <grass-bugs@intevation.de>
Subject: complete text file
MIME-Version: 1.0
Content-Type: multipart/alternative;
  boundary="----=_Part_96603_15034519.1157281527913"
X-Virus-Scanned: by amavisd-new at intevation.de
X-Spam-Status: No, hits=-4.398 tagged_above=-999 required=3
tests=[BAYES_00=-5, HTML_40_50=0.035, HTML_MESSAGE=0.5, RCVD_BY_IP=0.067]
X-Spam-Level:
