[GRASS-dev] [bug #5094] (grass) r.support from the GUI is broken
this bug's URL: http://intevation.de/rt/webrt?serial_num=5094
Subject: r.support from the GUI is broken
If you launch r.support (r.support.sh actually) from the gis.m menu, you get
to pick a map and then launch r.support in an xterm. As soon as you enter "y"
or "n" at the prompt the xterm disappears. Replace "execute r.support.sh" with
"term r.support" on line ~421 of menu.tcl for comparison with what should happen.
The grass-run.sh script pauses if the module exited with an error. Maybe
grass-xterm-wrapper should too? (this doesn't seem to help with the r.support
problem though)
Hamish
problem though)
There is no point doing it in grass-xterm-wrapper, for several
reasons:
1. grass-xterm-wrapper's stdout will typically be the pipe set up by
Tcl's "exec" or "open |..." commands, its stderr will either refer to
the same pipe or be redirected to /dev/null, and it won't have a
stdin.
2. Once $GRASS_XTERM completes, the terminal window has gone; there
doesn't seem to be much point pausing here.
3. xterm's exit code doesn't reflect the exit code of the program
which is run via -e, so grass-xterm-wrapper doesn't know whether the
command succeeded or failed.
4. Anything which d.m/gis.m run via an xterm needs to use grass-run.sh
(otherwise the program may be unable to find the GRASS shared
libraries), which already includes the pause.
