[GRASS-dev] [bug #5097] (grass) d.vect.chart: add where option
guest wrote (Mon, Sep 4 2006 16:52:02):
It would be great to have a 'where' option in d.vect.chart.
Maritz,
AFAIU your new d.vect.chart version recently published on grass-dev list
adresses this, is that correct? Will it be applied into CVS and is it meant to
replace d.vect.chart in future (for GRASS 7)?
Best,
Maciek
Maritz,
yes
meant to
I will certainly try to add some more improvements (e.g. allow the use of
arbitrary icons), and I hope to integrate some elements of a future
C-version of d.vect.thematic (i.e. allow thematic coloring of proportional
icons), so the code might still change a bit.
But in my opinion, it should probably soon go into CVS, so that others can
work on it if they so wish.
I was waiting for an answer on how to handle this, though, i.e. should I
create a d.vect.chart2 directory ?
I imagine, yes.
Especially if we go a bit further in the idea of allowing arbitrary sql
queries in vector commands (see experimental d.vect.chart.sql I posted to
the list).
Moritz
