[GRASS-dev] [bug #5098] (grass) gis.m; tcltk error when zooming to map with name which exists in more than one mapset
this bug's URL: http://intevation.de/rt/webrt?serial_num=5098
Subject: gis.m; tcltk error when zooming to map with name which exists in more than one mapset
Platform: GNU/Linux/x86
grass obtained from: CVS
GRASS Version: cvs_head_20060904
When there are two maps with the same name in more than one of the accessible mapsets, then gis.m throws below tcltk error when I try to "zoom to selected map". To reproduce in spearfish, just copy any map from the PERMANENT mapset to the user1 mapset using the same name and then display it and zoom to it. If I enter @mapsetname (i.e. @user1) after the map name zooming to the map works.
It is probably just a question of catching the WARNING message and ignoring it, or of adding the @mapsetname automatically (default to current mapset if not set otherwise).
BTW, I find the warning message a bit weird: when I display roads from user1 I get the message "WARNING: 'vector/roads' was found in more mapsets (also found in user1)". In my understanding this should read "... (also found in PERMANENT)...
WARNING: 'vector/roads' was found in more mapsets (also found in user1).
    while executing
"close $input"
    (procedure "MapCanvas::zoom_gregion" line 11)
    invoked from within
"MapCanvas::zoom_gregion $mon [list "vect=$map"]"
    (procedure "MapCanvas::zoom_map" line 48)
    invoked from within
"MapCanvas::zoom_map $mon"
    invoked from within
".mapcan(1).mf.topf.tb0.mapzoom.zm invoke active"
    ("uplevel" body line 1)
    invoked from within
"uplevel #0 [list $w invoke active]"
    (procedure "tk::MenuInvoke" line 50)
    invoked from within
"tk::MenuInvoke .mapcan(1).mf.topf.tb0.mapzoom.zm 1"
    (command bound to event)
Moritz
Whenever any Tcl/Tk code runs a GRASS command, it needs to use
"2>@stdout". Tcl treats it as an error if anything is written to
stderr.
Genuine errors will still be detected by a non-zero exit code.
Maceij has reported this too.
I'm trying to do a bunch of comprehensive bug fixes (they never seem to end)
to gism. I think I've fixed this one.
I was finally able to reproduce a strange one that he also reported about
zooming when 2 or more map display are visible. Reproducing it on my Mac was
difficult, but fixing this was much harder. But I think I got it.
This has involved changing most of the many global variables floating around
to ones tied to local name spaces, and replacing other variables with arrays
indexed by active display monitor.
I hope to get this committed either tomorrow or Wednesday.
Hopefully, this will make the whole system more robust.
Michael
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Reply-To: Request Tracker <grass-bugs@intevation.de>
Date: Mon, 4 Sep 2006 18:13:15 +0200 (CEST)
To: <grass-dev@grass.itc.it>
Subject: [GRASS-dev] [bug #5098] (grass) gis.m; tcltk error when zooming to
than one mapset
not set otherwise).
PERMANENT)...
    while executing
"close $input"
    invoked from within
    invoked from within
    invoked from within
    invoked from within
    invoked from within
Moritz
I'm doing a bunch of fixes (they never seem to end do they?) prompted by a
weird bug report by Maciej about odd behavior zooming between two map
displays. This was tricky to reproduce on my Mac and much more difficult to
fix. I think I got it, but it involved changing most of the many global
variables floating around to variables within local namespaces, and indexing
more variables by active display monitor.
I also found and dispatched a few other hidden bugs and bugs waiting to
happen.
I've fixed this one too I hope. Maciej and other have reported it before,
but it has been intermittent on my Mac--making a fix difficult.
This cleanup should make the whole application more robust.
I want to commit all this tomorrow or on Wednesday (depending on my schedule
and access to the cvs tomorrow).
Michael
phone: 480-965-6213
fax: 480-965-7671
PERMANENT)...
to gism.
:wink:
I will be glad to test it but I'm away 05-09 Sept. and *propably* will
not have an Internet connection during that time. Yet if the meeting is
boring and there's net available I could entertain myself a bit testing
the gis.m :). We'll see.
Maciek
stderr.
Are all GRASS commands called by grass-xterm-wrapper and grass-run.sh?
If so, can we just move this redirection to grass-xterm-wrapper so that
Windows users are happy? $mingw test for separate redirection is ugly.
Huidae
> stderr.
No. Those are only used for commands which need to be run in an xterm
because they interact with the user via a terminal. They aren't used
for modules which can operate without user interaction (i.e. the
majority of GRASS modules).
