[GRASS-dev] [bug #5129] (grass) ps.map: vpoints with sizecol not sorted to put larger behind smaller icons
this bug's URL: http://intevation.de/rt/webrt?serial_num=5129
Subject: ps.map: vpoints with sizecol not sorted to put larger behind smaller icons
Platform: GNU/Linux/x86
grass obtained from: CVS
GRASS Version: cvs_head_20060912
When creating sizeable point symbols with the vpoints command and the sizecol option, ps.map does not sort the icons so that larger are behind smaller ones. This can make smaller ones invisible sometimes.
Moritz
