[GRASS-dev] [bug #5167] (grass) v.patch: -a(ppend) issues
mneteler wrote (Wed, May 9 2007 21:29:19):
If you try
v.db.select map2
ERROR: Database connection not defined
you see that there is no DB connection. Why? Because v.random
doesn't attach a table (use v.db.addtable for this).
Sorry but I don't get it. Why are you talking about a table? The "v.patch -a"
has nothing to do with it.
The given v.patch command looks pretty unusual to me:
- append to an existing map where you have to specify "overwrite"??
Pretty counterintuitive!
Anyway, isn't that strange that the output of a valid command (according to
manual) is corrupted, so that GRASS can use it and QGIS can't, until v.build
is run on it?
I do realize that the command looks strange, but I thought this issue might be
and indicator of something wrong with v.patch.
Closing,
Hmm.
Maciek
