[GRASS-dev] [bug #5168] (grass) v.in.ogr: undefined symbol OGRRegisterAll
John Mockus wrote:
PC AMD-X86_64 Fc5 (Fedora-core-5)
grass-6.3.cvs-x86_64-unknown-linux-gnu-23_09_2006.tar.gz
$ v.in.ogr dsn=adm.e00 output=adm1
v.in.ogr: symbol lookup error: v.in.ogr: undefined symbol:
OGRRegisterAll
John,
I tried the E00 file you sent me. I can't reproduce the error. I set up a
location that matches your E00 and imported it without any error:
$ v.in.ogr dsn=~/tmp/adm.e00 output=adm1
A datum name wgs84 (WGS_1984) was specified without transformation parameters.
Note that the GRASS default for wgs84 is towgs84=0.000,0.000,0.000.
Projection of input dataset and current location appear to match.
Proceeding with import...
Layer: ARC
WARNING: Column name changed: 'ADM#' -> 'ADM_'
WARNING: Column name changed: 'ADM-ID' -> 'ADM_ID'
Building topology ...
3 primitives registered
0 areas built
0 isles built
Attaching islands:
Attaching centroids: Topology was built.
Number of nodes : 6
Number of primitives: 3
Number of points : 0
Number of lines : 3
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
I can display it and so on.
This makes me think that the error you get might be due to a corrupted
instalation of GDAL or GRASS, or an incompatibility of either one with 64 bit
machine you use (I'm on 32 bit myself). Can you reproduce the error using
latest GRASS 6.3 CVS and GDAL 1.3.2?
CCing grass-dev: Anydody - any thoughts?
Maciek
