this bug's URL: http://intevation.de/rt/webrt?serial_num=5175
Subject: v.to.db: 'option=cat' not updating columns other than 'cat'
Even if I specify a valid integer output 'column' for 'option=cat':
v.to.db -s map=huha2 type=point layer=2 option=cat column=gimme
v.to.db ignores it and updates the column "cat" instead:
Updating database ...
insert into huha2_2 ( cat ) values ( 1 )
insert into huha2_2 ( cat ) values ( 2 )
insert into huha2_2 ( cat ) values ( 3 )
... and so forth.
The column "gimme" is there:
$ v.info -c huha2
Displaying column types/names for database connection of layer 1:
INTEGER|cat
INTEGER|gimme
Why does v.to.db ignore it? I thought I could use any integer column for
storing categories...
Maciek
