Any query with d.what.vect in GUI mode results in:
WARNING: Color: can't set color 50331648
I forgot to add that the WARNING is printed to terminal.
The exact to reproduce this is:
1. d.m
2. display a vector
3. press ? icon in d.m
4. query - you will get the expected output in the tcl/tk window and a
"WARNING: Color: can't set color 50331648" in the terminal
BTW, do we need "Done." message in d.what.vect? d.what.rast doesn't print it...
Maciek
1. d.m
2. display a vector
works for me.
6.3-cvs, d.m + spearfish60 fields (no centroids, rand colors) map, roads
map.
print it...
It's there so when called from d.m, in the terminal window the last text
changes from:
Buttons
Left: what's here
Middle: toggle flash color
Right: quit
otherwise someone might think they can still click after they've right
clicked.
middle click to change flash color doesn't seem to work for me (?)
Also it doesn't flash if you click where an undisplayed centroid is.
