[GRASS-dev] [bug #5205] (grass) r.colors color=rules: few seconds delay between each warning
this bug's URL: http://intevation.de/rt/webrt?serial_num=5205
Subject: r.colors color=rules: few seconds delay between each warning
If one makes a mistake in rules, resuming from each warning takes few sec.
eg.
$ r.colors map color=rules
Data range is 0 to 5
[ENTER]
WARNING: bad color specification
[few seconds]
WARNING: rule is not added
[few seconds]
Maciek
eg.
> [ENTER]
[few seconds]
[few seconds]
The delay is built into lib/gis/error.c; it should be removed, IMHO.
> warning
> few sec.
> eg.
> > [ENTER]
> [few seconds]
> [few seconds]
the delay is there for interactive modules which clear the screen; if
there is no delay there is no chance to see the warning before the
terminal blanks and know that something is wrong.
these modules call:
  G_sleep_on_error(1);
the default is:
  G_sleep_on_error(0);
the problem with r.colors is that raster/r.colors/main.c explicitly
calls G_sleep_on_error(1);
Hamish
> > warning
> > few sec.
> > eg.
> > > [ENTER]
> > [few seconds]
> > [few seconds]
these modules call:
the default is:
I have removed the G_sleep_on_error() calls.
