this bug's URL: http://intevation.de/rt/webrt?serial_num=5210
Request number 5210 was commented on by 'msieczka' (Maciek Sieczka).
Responding to this message will send mail to the requestor.
Request Tracker
rt@intevation.de
Cc: grass-dev@grass.itc.it
Re-opening the bug.
hbowman wrote (Mon, Nov 20 2006 02:59:07):
is the interactive Vask part even functional?
I confirm it's not in v.transform. IMHO the option to provide the
transformation in a text file (pointsfile) should be left as is, and the
interactive part removed. I think it would be safe, because:
1. AFAIK, interactive v.transform never worked (did it?)
2. even if worked, interactive functionality it is not that likely to be used
in user scripts
3. I often heard that one of the current aims of GRASS is to get rid of
interactive functionality if possible - isn't this a good candidate?
Maciek
