[GRASS-dev] [bug #5217] (grass) wingrass: creating new location from startup screen fails with georeferenced file
this bug's URL: http://intevation.de/rt/webrt?serial_num=5217
Subject: wingrass: creating new location from startup screen fails with georeferenced file
Platform: WindowsNT/2000/XP
grass obtained from: Other (CDROM etc)
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: huidae's wingrass version sept. 17
Trying to create a new location from the startup screen in wingrass using a georeferenced file gives the following error:
channel "console2" wasn't opened for writing
    while executing
"exec -- g.proj -c georef=$filepath location=$fileLocation >@stdout 2>@stderr"
    invoked from within
".fileloc.def invoke"
    ("uplevel" body line 1)
    invoked from within
"uplevel #0 [list $w invoke]"
    (procedure "tk::ButtonUp" line 24)
    invoked from within
"tk::ButtonUp .fileloc.def
    (command bound to event)
Moritz
georeferenced file
    while executing
2>@stderr"
    invoked from within
    invoked from within
    invoked from within
I do not get this error if I start grass from a msys terminal, instead of
using grass.bat.
Any reason to use cmd.exe as terminal, instead of the msys terminal ?
Moritz
