[GRASS-dev] [bug #5220] (grass) wingrass: v.in.ogr (tcltk version) creates wrong directory path
this bug's URL: http://intevation.de/rt/webrt?serial_num=5220
Subject: wingrass: v.in.ogr (tcltk version) creates wrong directory path
Platform: WindowsNT/2000/XP
grass obtained from: Other (CDROM etc)
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: huidae's wingrass version sept. 17c
Directory paths created by the tcktk dialogs (navigate to find file buttons) do not work in wingrass. They are created in the form c:/moritz, but in order for them to be recognized, they should be in the form /c/moritz.
Moritz
The tcltk file browser is a prebuilt widget. The Windows version apparently
returns files in proper Windows format. If all file parsing for windows
platforms should switch from c:/ to /c/, this could be parsed in an if
clause to test for windows platform. Is this kind of reparsing needed
universally for windows or just in some places? It would take some effort to
track down and change in the appropriate places (most importantly in
gui.tcl), but it is doable.
Michael
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Reply-To: Request Tracker <grass-bugs@intevation.de>
Date: Thu, 19 Oct 2006 11:48:10 +0200 (CEST)
To: <grass-dev@grass.itc.it>
Subject: [GRASS-dev] [bug #5220] (grass) wingrass: v.in.ogr (tcltk version)
Moritz
the form /c/moritz.
That depends upon the Tcl/Tk implementation. For a native Windows
Tcl/Tk implementation, you would have to use c:\moritz. The /c/moritz
syntax is part of MinGW/Cygwin; it isn't valid within Windows itself.
Probably the safest solution is to use Tcl's "file" command to manage
filenames, rather than trying to do it manually using string
operations. The following sub-commands appear relevant.
       file dirname name
       file extension name
       file join name ?name ...?
       file nativename name
       file normalize name
       file pathtype name
       file rootname name
       file separator ?name?
       file split name
       file tail name
       file volumes
Notes:
1. While most Windows API calls accept both '\' and '/', most
console-mode commands only accept '\', as '/' is used for switches
(which needn't be preceded by a space; "dir foo/w" is equivalent to
"dir foo /w" or "dir /w foo"). You probably need to use
"file nativename" for any filenames passed to Tcl's "exec" command.
2. Don't forget about UNC paths: \\server\share\path\to\file.txt
3. There is some additional information in the filename(n) manpage.
Thanks Glynn,
This is a good way to parse these. However, if we will have to reassemble
the pieces in a 'nonstandard', it may still require a string function
somewhere (e.g., file join will create a 'proper' path for the platform in
question). What I'm not sure of and hope someone can check is whether you
need to use this format for both reading and writing, in all modules, and
how you specify a server (does \\server\share\path\to\file.txt work?) in
this environment.
Michael
Center for Social Dynamics and Complexity
phone: 480-965-6213
fax: 480-965-7671
Date: Thu, 19 Oct 2006 19:21:54 +0100
Cc: <grass-dev@grass.itc.it>
Subject: Re: [GRASS-dev] [bug #5220] (grass) wingrass: v.in.ogr (tcltk
the form /c/moritz.
       file dirname name
       file extension name
       file normalize name
       file pathtype name
       file rootname name
       file split name
       file tail name
       file volumes
Notes:
