this bug's URL: http://intevation.de/rt/webrt?serial_num=5247
Subject: references to "grass61"
these should proably be updated:
grass63$ grep -rI grass61 *
INSTALL: the CVS repository), e.g. grass61src_cvs_snapshot_exp_2005_03_19.tar.gz
SUBMITTING_SCRIPTS:
http://grass.ibiblio.org/grass61/manuals/html61_user/g.parser.html
gem/docs/GEM-Manual.tex:\emph{/Applications/Grass/grass61cvs.app/Contents/Resources/grass-6.1.cvs}
gem/docs/GEM-Manual.lyx:/Applications/Grass/grass61cvs.app/Contents/Resources/grass-6.1.cvs
gem/docs/GEM-Manual/GEM-Manual.html:<I>/Applications/Grass/grass61cvs.app/Contents/Resources/grass-6.1.cvs</I>
gem/docs/GEM-Manual/index.html:<I>/Applications/Grass/grass61cvs.app/Contents/Resources/grass-6.1.cvs</I>
gem/main.c: - make install action to copy executable GEM to /usr/local or
wherever grass61
lib/init/README: "grass61" starts up d.m by default (if not first time user).
lib/init/README: "grass61 -text" will start up in text mode.
lib/init/README: "grass61 -tcltk" or "grass61 -gui" will start up in tcltk mode.
lib/init/README: You can use alias "grass61" to "grass61 -text" to use text
mode by default.
lib/init/README: grass61 - # non-interactive startup using
LOCATION location
lib/init/README: Also, the first argument of grass61 can override these env vars.
lib/init/README: grass61 /usr/home/grass/usr/data2/loc2-1/map1-1
lib/init/README: grass61 map1-1 # non-interactive startup using
lib/init/README: grass61 loc2-1/map1-1
lib/init/grass6.html:<EM><B>grass61</B></EM> - The GRASS startup program<BR>
lib/init/grass6.html:<B>grass61</B> [<B>-</B>] [<B>-v</B>] [<B>-h | -help |
--help</B>] [<B>-text | -tcltk | -gui</B>]
lib/init/grass6.html:Thus, the next time the user runs GRASS, typing
<EM>grass61</EM> (without any
lib/init/grass6.html:If you specify a graphical user interface (eg Tcl/Tk) the
<EM>grass61</EM>
lib/init/grass6.html:can access it successfully. If any of these checks fail,
then <EM>grass61</EM>
lib/init/grass6.html:The <EM>grass61</EM> program will check for the existence
of an environment
lib/init/grass6.html:GRASS to use. If this variable is not set when
<EM>grass61</EM> is run, then
lib/init/grass6.html:There is an order of precedence in the way
<EM>grass61</EM> determines the user
lib/init/grass6.html: grass61 -<BR><BR>
lib/init/grass6.html: grass61 /usr/home/grass/data/thailand/forests<BR><BR>
lib/init/grass6.html: grass61 swamps<BR><BR>
lib/init/grass6.html: grass61 thailand/forests<BR><BR>
lib/init/grass6.html:<DT><B>grass61</B>
lib/init/grass6.html:<DT><B>grass61 -tcltk</B>
lib/init/grass6.html:<DT><B>grass61 -text</B>
lib/init/grass6.html:<DT><B>grass61 -tcltk -</B>
lib/init/grass6.html:<EM>$UNIX_BIN/grass61</EM> - GRASS startup program<BR><BR>
lib/init/grass6.html: <EM>grass61</EM><BR><BR>
swig/swiglib.dox:<li> in the <a
href="http://grass.itc.it/grass61/source/snapshot/">weekly CVS snapshot</a>
(swig/ subdirectory)
Hamish
