this bug's URL: http://intevation.de/rt/webrt?serial_num=5258
hamish_nospam@yahoo.com wrote (Sun, Nov 5 2006 06:45:09):
Guido Lorenz wrote:
v.patch -e input=paguirre2006base4,testarea output=testpatch
--overwrite GRASS_INFO_ERROR(28119,1): Missing tableManually creating a database table in PostgreSQL, connecting it to the
vector file (v.db.connect) and updloading the cat values is a simple
workaround so far.
v.in.region creates a vector box -- it has no attributes that need
storing in a table.
The problem is with v.patch. It will not work if used with -e while any of the
input vectors doesn't have a table. I'm renaming the bug.
I can't comment on PosgreSQL or deriative needs.
This is not related to Postgres. With DBF it's the same.
Moreover, v.patch segfaults if used with -e while *neither* input vector has a
table. See the follwoing examples:
in spearfish60:
$ v.random out=pt1 n=10
$ v.random out=pt2 n=10
### CASE 1: neither input vector has a table:
$ v.patch input=pt1,pt2 out=ptp -e
Segmentation fault (core dumped)
$ gdb v.patch core
(gdb) bt
#0 0x0804a29f in main (argc=0, argv=0xbfcdf604) at main.c:193
(gdb) q
### CASE 2: only one input vector doesn't have a table:
$ v.db.addtable pt1 columns="cat integer"
ERROR: Missing table
### CASE 3: both input vectors have a table:
$ v.db.addtable pt2 columns="cat integer"
(works)
Maciek
