this bug's URL: http://intevation.de/rt/webrt?serial_num=5260
Subject: r.terraflow will not compile
Platform: GNU/Linux/x86
grass obtained from: Trento Italy site
GRASS Version: 6.2.0 & latest 6.3 CVS
I could not compile r.terraflow in Fedora Core 6. Another user had similar error. See: http://grass.itc.it/pipermail/grass-dev/2006-October/026953.html
I found thread where 5.7 apparently had same or similar problem. I was able to compile by removing <T, Compare> on line 120 in replacementHeap.h and on line 122 in replacementHeapBlock.h I have not tested it but it does compile without errors after those changes.
Floyd
