this bug's URL: http://intevation.de/rt/webrt?serial_num=5263
Subject: r.to.vect: -v flag doesn't transfer cat values
If I make a stream map with r.watershed,
then
r.null rwater.stream setnull=0
r.to.vect -v in=rwat.stream out=rwat_stream feature=line
Extracting lines ... 100%
100%
Building topology ...
17 primitives registered
Building areas: 100%
0 areas built
0 isles built
Attaching islands:
Attaching centroids: 100%
Topology was built.
Number of nodes : 24
Number of primitives: 17
Number of points : 0
Number of lines : 17
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
r.to.vect complete.
the vector map is created but the lines have no cats
v.info:
| Number of dblinks: 0
the input map is CELL, raster range is min=2 max=64.
the -v flag was used with r.to.vect.
G63> db.connect -p
driver:dbf
database:$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
schema:(null)
group:(null)
thanks,
Hamish
