[GRASS-dev] [bug #5264] (grass) v.digit - G_malloc out of memory error
guest wrote (Fri, Nov 10 2006 02:31:16):
trying to create a new vector file results in the following error:
v.digit -n map=testv2
New empty map created.
ERROR: G_malloc: out of memory
Hi, thanks for the report. v.digit works for me. Nobody seems to be confirming
this bug. So a few questions:
GRASS version exactly?
Linux?
region settings?
tcl/tk version (build time and run time, if different)?
When trying to edit an existing vector file, the following message appears:
v.digit map=filename
ERROR: Cannot open old vector filename4@PERMANENT on level 2
That's because v.digit crashes and leaves the vector without topology.
Maciek
v.digit should be(come) friendly and run v.build (or the equivalent C stuff)
to reconstruct the topology.
