[GRASS-dev] [bug #5264] (grass) v.digit - G_malloc out of memory error
neteler@itc.it wrote (Sat, Nov 11 2006 16:29:58):
v.digit should be(come) friendly and run v.build (or the equivalent C stuff)
to reconstruct the topology.
That's one thing. The other is that it shows that v.digit crashes at startup
if the region is particulary big. Eg. if in spearfish I do:
$ g.region s=0 n=999999999 w=0 e=999999999 res=1 -a
v.digit fails as follows:
$ v.digit -n test
New empty map created.
ERROR: G_malloc: out of memory
In a communication offlist Guido Lorenz (the reporter) confirms this with his
dataset.
Maciek
startup if the region is particulary big. Eg. if in spearfish I do:
$ v.digit -n test
with his dataset.
can this be reproduced with a realistic region size?
(I'm not saying it isn't something that shouldn't be looked into, but
I'm not too worried about GRASS failing gracefully when the user has
defined a region bigger than their system can handle, ~ 100,000 x
100,000 cells (40gb?))
Hamish
By setting the region (no matter how big) you don't create any "40 GB
data". And you don't create any such huge dataset either by running
'v.digit -n test' and drawing a line. IOW, there is no reason v.digit
should crash in the given circumstances.
Maciek
[ http://intevation.de/rt/webrt?serial_num=5264 ]
v.digit -n map=testv2
> but I'm not too worried about GRASS failing gracefully when the user
> has defined a region bigger than their system can handle, ~ 100,000
> x 100,000 cells (40gb?))
shouldn't .. and yet it does.
fwiw,
grass63/vector/v.digit$ grep G_malloc *
cat.c: MaxFieldCat = (void *) G_malloc ( (aMaxFieldCat) * sizeof(int) * 2 );
symb.c: LineSymb = (int *) G_malloc ( (aLineSymb + 1) * sizeof(int) );
symb.c: NodeSymb = (int *) G_malloc ( (aNodeSymb + 1) * sizeof(int) );
you'd have to run it through the debugger to find which G_malloc call is
the guilty one. (or if it's from another lib fn call external to
v.digit)
for me, I can set the res this fine before it crashes: (spearfish)
# v.digit still works
G63> g.region res=0.0002 -p
nsres: 0.0002
ewres: 0.0002
rows: 69900000
cols: 94950000
cells: 6637005000000000
#v.digit crashes
G63> g.region res=0.0001 -p
nsres: 0.0001
ewres: 0.0001
rows: 139800000
cols: 189900000
cells: 26548020000000000
after that setting res back to 10m doesn't help. I always get the error
until restarting GRASS. I guess the # of cells is overflowing into a
static variable? or more probably just generally breaking the
G_get_window() & co calls ??
again, these region settings are totally unrealistic, but cleaning up
after bogus region settings shouldn't break the entire grass session.
Hamish
