this bug's URL: http://intevation.de/rt/webrt?serial_num=5300
Subject: ./configure misses missing libxmu headers
Platform: GNU/Linux/x86
grass obtained from: Trento Italy site
GRASS Version: 6.2.0
./configure script somehow missed that I do not have libxmu header files. On
Debian system those headers are provided with libxmu-dev package.
libxmu is used by nviz.
The configure script still treats X11 as an atomic package. This could
cause problems on platforms which have started using modular X11
packages.
I don't know whether newer versions of autoconf include tests for
individual X11 components, but autoconf 2.13 doesn't, and I wouldn't
want to force an upgrade over this issue alone.
It should be safe to check for X11 libraries and headers like any
other, provided that the relevant compiler/linker switches are used.
For header checks, $X_CFLAGS needs to be added, while library checks
need to use:
$X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS
See the checks for Motif, OpenGL and Tk for examples.
BTW, it's actually Togl which uses Xmu (XmuLookupStandardColormap).
