[GRASS-dev] [bug #5341] (grass) v.db.select: segfault
neteler@itc.it wrote (Mon, Nov 27 2006 19:08:21):
the graphical frontend to gdb, will get you to the offending line.
There you can check variable settings before the program crashes and so
forth.
I don't know a thing about C, or any other programming language (only basics
of shell and awk). Thus I really doubt debugging C code by me makes much sense.
Maybe you could give 'ddd' a try first? It's really not so difficult.
But I need to now something about how C works, more or less, don't I?
Do you suppose the problem could be due to my setup, not the v.db.select code?
I would greatly appreciate if anybody could try reproducing the segfault.
Maciek
you can still find out where it breaks, without understanding the "why".
some gdb hints:
GRASS> gdb `which v.db.select`
(gdb) run map=foo where="this = 'that'"
<segfault>
#full backtrace
(gdb) bt f
#list code at point in source code where it broke
(gdb) l
#change function reference frame (#1, #2, #3, ... in bt list)
frame <number>
#list code at breakpoint (in new frame)
(gdb) l
#print variable value at this point ("bt full" shows all values)
(gdb) p <variable name>
Hamish
