[GRASS-dev] [bug #5341] (grass) v.db.select: segfault
rez@touchofmadness.com wrote (Mon, Nov 27 2006 22:37:23):
I just downloaded the test dataset (from original email) and executed
v.db.select with the parameters specified (it's MAPS_COVER, not
MAP_COVER).
I didn't wrote it was MAP_COVER. Where did you find it?
Everything completes fine for me and without error.
Can you sepcify the platform and GCC version?
Thanks for testing this!
Best,
Maciek
> MAP_COVER).
My mistake. I read it wrong.
x86_64 gcc-3.2.3 and gcc-4.1.1.
Brad Douglas <rez touchofmadness com> KB8UYR/6
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
