hamish_nospam@yahoo.com wrote (Tue, Nov 28 2006 00:13:48):
Hamish and All,
Thanks for the hints!
I did some (cough)de(cough)bugging. I have put the coredump for others to try:
http://kufaya.googlepages.com/core.bz2
To use it:
$ grass63 (any location)
$ gdb v.db.select core
(gdb) bt
#0 0xb76b3943 in free () from /lib/tls/i686/cmov/libc.so.6
#1 0xb76b4a86 in realloc () from /lib/tls/i686/cmov/libc.so.6
#2 0xb7f50069 in db_realloc (s=0x38, n=1293960530) at alloc.c:76
#3 0xb7f53e12 in db_enlarge_string (x=0xbfc9bfd8, len=134832184)
at string.c:133
#4 0xb7f5407f in db_append_string (x=0xbfc9bfd8,
s=0x8096040 " WHERE MAPS_COVER='built up'") at string.c:220
#5 0x080494ee in main (argc=3, argv=0x8096040) at main.c:122
(gdb)
Below is the code where it segfaults (frame #5, I guess):
(gdb) l
122 db_append_string ( &sql, buf );
123 }
124
125 if (db_open_select_cursor(driver, &sql, &cursor, DB_SEQUENTIAL) !=
DB_OK)
126 G_fatal_error(_("Cannot open select cursor"));
127
128 table = db_get_cursor_table (&cursor);
129 ncols = db_get_table_number_of_columns (table);
130
131 /* column names if horizontal output */
(gdb)
Any good? The coredump is available, anybody savvy can try themselves.
Maciek
Hamish and All,
To use it:
(gdb) bt
at string.c:133
(gdb)
(gdb) l
123 }
124
DB_OK)
127
130
(gdb)
The problem is with db_append_string(). I just committed a patch that
handles memory properly before the call, but I don't know if it will be
of any help. Give it a try.
Brad Douglas <rez touchofmadness com> KB8UYR/6
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
