[GRASS-dev] [bug #5396] (grass) hermannskogel datum parameters for Slovakia
this bug's URL: http://intevation.de/rt/webrt?serial_num=5396
Subject: hermannskogel datum parameters for Slovakia
Platform: GNU/Linux/x86
grass obtained from: Trento Italy site
Hermannskogel datum parameters for Slovakia (Krovak projection) are wrong. The estimated error for these parameters is about 120-130 m.
Unless proper parameters are available I suggest to use parameters for Czech republic which give acceptable results with 1-3 meter error.
The item for Slovakia should be removed from menu and item for Czech republic (1.) could be extended to include also Slovakia.
The evaluation was done using local cartographic tools (Samuel for ArcView and Dattra).
after discussion in the CzechoSlovak mailing list I fixed this bug,
there is common geodetic datum for Czech Republic and Slovakia.
hermannskogel "towgs84=570.8,85.7,462.8,4.998,1.587,5.261,3.56" "Czech
Republic/Slovakia" " "
Best, Martin
2006/12/18, Request Tracker <grass-bugs@intevation.de>:
grass-dev mailing list
grass-dev@grass.itc.it
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
Hi Martin,
should this also go into 6.2-CVS?
On Tue, Dec 19, 2006 at 10:32:13AM +0100, Martin Landa wrote:
Best, Martin
>and Dattra).
>_______________________________________________
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
Hi Markus,
I think it should be also fixed in 6.2-CVS (maybe some of my Slovak
friends can confirm it;-)
Martin
2006/12/19, Markus Neteler <neteler@itc.it>:
Hi Martin,
> Hi all,
> Best, Martin
> >and Dattra).
