> I experienced problems with Ubuntu 6.10 installation. The r.in.wms
> script refused to work with errors like this:
> /usr/lib/grass/etc/r.in.wms//wms.request: 326: SIZE_ARRAY[0]=: not
> found /usr/lib/grass/scripts/r.tileset: 193: declare: not found
> /usr/lib/grass/scripts/r.tileset: 258: Syntax error: Bad for loop
> variable
> It took me about a couple of hours to find out that the reason is
> that Ubuntu developers decided to change the symbolic link /bin/sh
> from /bin/bash to /bin/dash, which is POSIX-compliant, but much less
> feature-rich than bash.
> Setting it back to /bin/bash solved the problem, but still
> indicating the right interpreter in the headers will also be great.
Maciek:
AFAIK, GRASS shell scripts are supposed to work with any POSIX 1003.2
compliant sh interpreter. Apparently some still don't, eg. r.tileset
and r.in.wms as we can see.
As the bash->dash switch in Ubuntu 6.1 seems inrevertable (see:
https://launchpad.net/ubuntu/+source/dash/+bug/61463, the comment by
Matthew Garrett at 2006-11-29 05:23:16 UTC, in particular), and it
looks justified from technical point of view, we have 3 options it
seems:
1. Have (some) GRASS sh scripts broken for Ubuntu (what if other
distros follow Ubuntu?). What with platforms not providing bash?
Markus and others have gone to a lot of trouble to remove all bashisms
from all the scripts/. AFAIK this is an isolated problem with r.tileset.
All we need to do is fix that and the job is done, all other scripts
should be free of Bashisms already.
2. Revise all the scripts and fix all bashisms; buts:
- who would do it?
Preferably the module's author. "No Bashisms" is in SUBMITTING_SCRIPTS.
But shell scripts are pretty easy to debug by adding -x.
Everyone can play along at home by changing the first line of the script
to "#!/bin/ash -x" and follow the output trail.
- it takes quite some knowledge to decide what needs to be fixed,
perhaps. some hints on common bashisms:
export VAR=foo
must be written as
VAR=foo
export VAR
$((exp)) doesn't work. use `expr` instead
use "=" not "==" for string compares
and it could take much time
probably not, if it is limited to r.in.wms + its support scripts.
- what with the addons? remove all that are not POSIX-compliant? fix
them ourselves? Anyway, much work.
Not our problem. They are provided as-is by their authors.
3. Change all GRASS sh scripts to require #/bin/bash. Least work. But
what with platforms not providing bash?
Not needed as it is only one script (family) that is broken?
Anyway, bug #5499 is from r.tileset:
if [ -z "$GIS_OPT_DESTSCALE" ] ; then
eval `g.proj -p | $GREP meters | $SED "s/\\s*:\\s*/=/"`
DEST_SCALE=$meters;
G63> g.proj -p | grep meters | sed "s/\\s*:\\s*/=/"
units = meters
meters = 1.0
^^^ it's trying to run that string as a program....
-x debug output:
+ eval units = meters meters = 1.0
++ units = meters meters = 1.0
Too many arguments (maybe you need quotes).
Try `units --help' for more information.
r.tileset --help
Parameters:
destscale Conversion factor from units to meters in source projection
I propose this fix:
Index: r.tileset
RCS file:
/home/grass/grassrepository/grass6/scripts/r.tileset/r.tileset,v
retrieving revision 1.3
diff -u -r1.3 r.tileset
--- r.tileset 19 Aug 2006 12:52:24 -0000 1.3
+++ r.tileset 19 Feb 2007 04:26:44 -0000
@@ -393,7 +393,7 @@
message 0 "Getting projection scale:"
- eval `g.proj -p | $GREP meters | $SED "s/\\s*:\\s*/=/"`
+ eval `g.proj -p | $GREP '^meters' | $SED -e "s/\\s*:\\s*/=/" -e "s/ //g"`
DEST_SCALE=$meters;
else
DEST_SCALE=$GIS_OPT_DESTSCALE
(my regex sucks, what does the "\\s*" part of "\\s*:\\s*" match?)
And adding exit code checks at vital junctures in the r.in.wms script so
it stops as soon as it breaks.
r.in.wms then goes on, but gdalwarp fails because
$GISDBASE/wms_download/wms_global_mosaic__0.geotiff is text not an image:
<?xml version='1.0' encoding="UTF-8" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM "http://www.digitalearth.gov/wmt/xml/exception_1_1_0.dtd ">
<ServiceExceptionReport version="1.1.0">
<ServiceException code="InvalidSRS">
The SRS "EPSG:4230" is invalid.
</ServiceException>
</ServiceExceptionReport>
(...proof that more sanity checks needed in the script!)
Hamish
