[GRASS-dev] [bug #5499] (grass) bash scripts starting with #!/bin/sh
msieczka wrote (Wed, Mar 28 2007 15:50:39):
In current 6.3 CVS there are several instances of "echo -e", which is a
bashism. In dash "echo -e" will just print '-e' string.
lib/gis/Makefile: echo -e "#include <stdlib.h>\n#include
<fcntl.h>\n#undef _fmode\nint _fmode = _O_BINARY;" > $(OBJDIR)/fmode.c
lib/init/grass-run.src: echo -e "\033]0;${TITLE}\007\c"
lib/init/grass-run.src: echo -e "\r"
These two instances make the grass-run.sh affected as well. "-e" is a bashism.
Since grass-run.sh has a "#!/bin/sh" shebang, even in bash in runs in a POSIX
shell compliant, thus prints spurious "-e"'s into the terminal.
Maciek
> is a bashism. In dash "echo -e" will just print '-e' string.
> $(OBJDIR)/fmode.c
left to someone else to fix. (I'm not big on Makefile fu)
bashism. Since grass-run.sh has a "#!/bin/sh" shebang, even in bash in
runs in a POSIX shell compliant, thus prints spurious "-e"'s into the
terminal.
fixed in CVS.
Hamish
I suggest putting the code into e.g. fmode.dat then using:
  cat fmode.dat > $(OBJDIR)/fmode.c
It can't be a normal .c file, as the default rules automatically
compile all .c files and link the resulting objects into the library.
