Hello,
Trying to rework d.vect.chart I am using the Vect_cidx_find_next() function.
However, using a map with areas I get behaviour which seems incorrect and which I cannot explain.
I have the following category index (result of Vect_cidx_dump(Map, stdout)):
[Field 0]
Field 1 number of unique cats: 589 number of cats: 1185 number of types: 3
type | count
8 | 592
4 | 1
64 | 592
category | type | line/area
11001 | 8 | 1895
11001 | 64 | 127
11002 | 8 | 1810
11002 | 64 | 42
11004 | 8 | 1874
11004 | 64 | 106
11005 | 8 | 1923
11005 | 64 | 155
11007 | 8 | 1866
etc.
Now, when I launch
Vect_cidx_find_next( Map, field_index=1, cat=11002, type=15, start_index=3, &stype, &sid )
it returns 4 and line id=1874.
This is wrong as the fourth item in the index, which does have line id 1874, has cat 11004 and not cat 11002. This is confirmed by launching
Vect_cidx_get_cat_by_index ( Map, field_index, 4, &testcat, &testtype, &testid)
which returns testcat = 11004.
Am I right in assuming that there is a bug in Vect_cidx_find_next, or am I misunderstanding something here ?
I don't have this problem with a pure point file, which only has one type:
Field 1 number of unique cats: 589 number of cats: 593 number of types: 1
type | count
1 | 593
11001 | 1 | 97
11002 | 1 | 12
11002 | 1 | 593
11004 | 1 | 76
11005 | 1 | 125
11007 | 1 | 68
So this seems to be linked to the type handling.
Any ideas,
Moritz
