[GRASS-dev] [BUG] or at least unclear error message
Hi
OS: OS X, El Capitan, grass installed via homebrew.
I have a mega location with 532 read-only mapsets with each around 2500 mapsets
(plus PERMANENT and an read-write analysis mapset).
When using g.list type=rast mapset=* I get the following error: "Unable
to open directory". I guess this is caused by to many open files as I
can execute the command g.list type=rast mapset=... for this mapset
without problems.
(transcript below)
Is this the case? Could the error message be clarified (I fear not) or a
different approach be used to list the maps?
Rainer
| simASM:grassAnalysis> g.list type=rast mapset=*
| ERROR: Unable to open directory
| /Users/rainerkrug/grassdata/simASM/simASM.CapePeninsula.Past.CapePeninsula_0_1.CapePeninsula.47712.2/cell
| simASM:grassAnalysis> g.list type=rast mapset=simASM.CapePeninsula.Past.CapePeninsula_0_1.CapePeninsula.47712.2 | wc -l
| 2615
| simASM:grassAnalysis> g.version -b -r -e --v
| GRASS 7.0.1 (2015)
| ./configure --prefix=/usr/local/Cellar/grass-70/7.0.1 --disable-debug --disable-dependency-tracking --enable-shared --with-cxx --with-python --with-blas --with-lapack --with-sqlite --with-odbc --with-geos=/usr/local/opt/geos/bin/geos-config --with-proj-share=/usr/local/opt/proj/share/proj --with-png --with-readline-includes=/usr/local/opt/readline/include --with-readline-libs=/usr/local/opt/readline/lib --with-readline --with-nls-includes=/usr/local/opt/gettext/include --with-nls-libs=/usr/local/opt/gettext/lib --with-nls --with-freetype --without-tcltk --with-includes=/usr/local/opt/gettext/include --with-wxwidgets=/usr/local/opt/wxmac/bin/wx-config --enable-64bit --with-macos-archs=x86_64 --with-cairo-includes=/usr/local/opt/cairo/include/cairo --with-cairo-libs=/usr/local/opt/cairo/lib --with-cairo --with-postgres --with-mysql-includes=/usr/local/opt/mysql/include/mysql --with-mysql-libs=/usr/local/opt/mysql/lib --with-mysql --with-liblas=/usr/local/opt/liblas/bin/liblas-config
| libgis Revision: 64733
| libgis Date: 2015-02-25 01:56:29 +0100 (Wed, 25 Feb 2015)
| PROJ.4: 4.9.1
| GDAL/OGR: 1.11.2
| GEOS: 3.4.2
| SQLite: 3.8.11.1
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
On Mon, Nov 2, 2015 at 11:50 AM, Rainer M Krug <Rainer@krugs.de> wrote:
Hi
without problems.
You likely hit the current setting of open files. See e.g. this page
how to set a higher limit:
https://grass.osgeo.org/grass70/manuals/r.series.html#management-of-open-file-limits
Please let us know how it goes.
Markus Neteler <neteler@osgeo.org> writes:
Hi
without problems.
Yes - that solved the issue. But I am wondering, if it really is
necessary to keep all these files open just to list the maps?
Rainer
South Africa
Skype: RMkrug
PGP: 0x0F52F982
without problems.
(transcript below)
G_ls2() doesn't call closedir() when it has finished reading the
directory.
Fixed in trunk with r66719.
Glynn Clements <glynn@gclements.plus.com> writes:
without problems.
(transcript below)
directory.
Thanks.
I assume this will not be included in 7.0.2?
Rainer
South Africa
Skype: RMkrug
PGP: 0x0F52F982
directory.
Thanks.
It will, already backported.
(but it didn't make it by some minutes into RC2).
directory.
Thanks.
Great - thanks
Rainer
South Africa
Skype: RMkrug
PGP: 0x0F52F982
Rainer M Krug <Rainer@krugs.de> writes:
Hi
without problems.
Just to add and possibly to be invcluded in the manual: on OS X the hard
limit is unlimited and the soft limit is 256.
Rainer
Rainer
South Africa
Skype: RMkrug
PGP: 0x0F52F982
maybe we should modify that part and refer to an overview page
describing the various operating systems?
I think that would be a good idea as this likely can affect many scripts
and commands.
Apart from the offline documentation, this might even a candidate for
the wiki.
Rainer
South Africa
Skype: RMkrug
PGP: 0x0F52F982
