Hi All
tring to build on osx on a fresh svn checkout :
export CXXFLAGS="-arch ppc -arch i386"
export CFLAGS="-arch ppc -arch i386"
export GDAL_BIN=/Library/Frameworks/GDAL.framework/unix/bin/
export NAD2BIN=/Library/Frameworks/PROJ.framework/Programs/nad2bin
../configure --with-freetype
--with-freetype-includes="/Library/Frameworks/FreeType.framework/unix/include/freetype2 /Library/Frameworks/FreeType.framework/unix/include"
--with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib
--with-gdal=/Library/Frameworks/GDAL.framework/Programs/gdal-config
--with-proj --with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include
--with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib
--with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj
--with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
--with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
--with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
--with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
--with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
--with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
--without-mysql --with-odbc --with-sqlite
--with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib
--with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include
--with-fftw-includes=/Library/Frameworks/FFTW3.framework/unix/include
--with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib --with-cxx
--with-opengl=aqua --with-x --without-motif --without-glw
--with-tcltk-includes="/Library/Frameworks/Tcl.framework/Headers /Library/Frameworks/Tk.framework/Headers /Library/Frameworks/Tk.framework/PrivateHeaders"
--with-python=/usr/bin/python-config --with-wxwidgets=/usr/bin/wx-config
--with-postgres --with-postgres-includes=/usr/local/pgsql/include/
--with-postgres-libs=/usr/local/pgsql/lib/ --enable-macosx-app
--prefix=/Applications/grass64svn
then :
open -a textmate include/make/platform.make
BEFORE RUNNNING MAKE i changed the TCLTKLIBS line to: -framework Tcl -framework Tk
and i removed render.c
make
Errors in:
/opt/gis/grass6_devel/lib/form
/opt/gis/grass6_devel/lib/vector/diglib
/opt/gis/grass6_devel/vector/v.digit
/opt/gis/grass6_devel/visualization/nviz
/opt/gis/grass6_devel/visualization/nviz2/cmd
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Sab 17 Gen 2009 12:42:54 CET
make: *** [default] Error 1
macbook-pro-15-di-sasha:grass6_devel sasha$ cd /opt/gis/grass6_devel/lib/form
macbook-pro-15-di-sasha:form sasha$ make
gcc -I/opt/gis/grass6_devel/dist.i386-apple-darwin9.6.0/include -arch ppc -arch i386 -fno-common -DPACKAGE=\""grasslibs"\" -I/usr/X11/include -I/Library/Frameworks/Tcl.framework/Headers -I/Library/Frameworks/Tk.framework/Headers -I/Library/Frameworks/Tk.framework/PrivateHeaders -I/Library/Frameworks/Tcl.framework/Headers -I/Library/Frameworks/Tk.framework/Headers -I/Library/Frameworks/Tk.framework/PrivateHeaders -DPACKAGE=\""grasslibs"\" -I/opt/gis/grass6_devel/dist.i386-apple-darwin9.6.0/include -o OBJ.i386-apple-darwin9.6.0/form.o -c form.c
form.c: In function ‘submit’:
form.c:195: error: ‘struct Tcl_Interp’ has no member named ‘result’
lipo: can't figure out the architecture type of: /var/folders/15/15zQj3qeHemLNapL-foqC++++TI/-Tmp-//ccuoxUul.out
make: *** [OBJ.i386-apple-darwin9.6.0/form.o] Error 1
macbook-pro-15-di-sasha:form sasha$ cd /opt/gis/grass6_devel/lib/vector/diglib
macbook-pro-15-di-sasha:diglib sasha$ make
make OBJ.i386-apple-darwin9.6.0/test
echo "==============TEST============="
gcc -L/opt/gis/grass6_devel/dist.i386-apple-darwin9.6.0/lib -L/usr/local/pgsql/lib/ -arch ppc -arch i386 -I/Library/Frameworks/GDAL.framework/Versions/1.6/Headers -I/opt/gis/grass6_devel/dist.i386-apple-darwin9.6.0/include -o OBJ.i386-apple-darwin9.6.0/test test.c -lgrass_dig2 -lgrass_gis -lgrass_datetime -lz -lgrass_rtree -lgrass_rtree \
-lgrass_gis -lgrass_datetime -lz -lgrass_datetime -lz
ld warning: in /opt/gis/grass6_devel/dist.i386-apple-darwin9.6.0/lib/libgrass_dig2.dylib, file is not of required architecture
ld warning: in /opt/gis/grass6_devel/dist.i386-apple-darwin9.6.0/lib/libgrass_gis.dylib, file is not of required architecture
ld warning: in /opt/gis/grass6_devel/dist.i386-apple-darwin9.6.0/lib/libgrass_datetime.dylib, file is not of required architecture
ld warning: in /opt/gis/grass6_devel/dist.i386-apple-darwin9.6.0/lib/libgrass_rtree.dylib, file is not of required architecture
Undefined symbols for architecture ppc:
"_dig_fflush", referenced from:
_main in ccyZnD8i.o
"_dig_set_cur_port", referenced from:
_main in ccyZnD8i.o
"_dig__fread_port_C", referenced from:
_main in ccyZnD8i.o
"_dig__fread_port_D", referenced from:
_main in ccyZnD8i.o
"_dig__fread_port_F", referenced from:
_main in ccyZnD8i.o
"_dig__fread_port_I", referenced from:
_main in ccyZnD8i.o
"_dig__fread_port_L", referenced from:
_main in ccyZnD8i.o
"_dig__fread_port_S", referenced from:
_main in ccyZnD8i.o
"_dig_fseek", referenced from:
_main in ccyZnD8i.o
"_dig__fwrite_port_C", referenced from:
_main in ccyZnD8i.o
"_dig__fwrite_port_D", referenced from:
_main in ccyZnD8i.o
"_dig__fwrite_port_F", referenced from:
_main in ccyZnD8i.o
"_dig__fwrite_port_I", referenced from:
_main in ccyZnD8i.o
"_dig__fwrite_port_L", referenced from:
_main in ccyZnD8i.o
"_dig__fwrite_port_S", referenced from:
_main in ccyZnD8i.o
"_dig_init_portable", referenced from:
_main in ccyZnD8i.o
ld: symbol(s) not found for architecture ppc
collect2: ld returned 1 exit status
lipo: can't open input file: /var/folders/15/15zQj3qeHemLNapL-foqC++++TI/-Tmp-//cch4lDVi.out (No such file or directory)
make[1]: *** [OBJ.i386-apple-darwin9.6.0/test] Error 1
make: *** [default] Error 2
macbook-pro-15-di-sasha:diglib sasha$ cd /opt/gis/grass6_devel/vector/v.digit
macbook-pro-15-di-sasha:v.digit sasha$ make
Makefile:20: warning: overriding commands for target `/opt/gis/grass6_devel/dist.i386-apple-darwin9.6.0/etc/v.digit'
.../../include/Make/Module.make:20: warning: ignoring old commands for target `/opt/gis/grass6_devel/dist.i386-apple-darwin9.6.0/etc/v.digit'
gcc -I/opt/gis/grass6_devel/dist.i386-apple-darwin9.6.0/include -arch ppc -arch i386 -I/usr/X11/include -I/Library/Frameworks/Tcl.framework/Headers -I/Library/Frameworks/Tk.framework/Headers -I/Library/Frameworks/Tk.framework/PrivateHeaders -I/Library/Frameworks/Tcl.framework/Headers -I/Library/Frameworks/Tk.framework/Headers -I/Library/Frameworks/Tk.framework/PrivateHeaders -I/Library/Frameworks/GDAL.framework/Versions/1.6/Headers -DPACKAGE=\""grassmods"\" -I/opt/gis/grass6_devel/dist.i386-apple-darwin9.6.0/include -o OBJ.i386-apple-darwin9.6.0/driver.o -c driver.c
driver.c: In function ‘driver_plot_icon’:
driver.c:54: error: ‘struct Tcl_Interp’ has no member named ‘result’
driver.c: In function ‘get_window’:
driver.c:61: error: ‘struct Tcl_Interp’ has no member named ‘result’
driver.c:68: error: ‘struct Tcl_Interp’ has no member named ‘result’
driver.c: In function ‘driver_open’:
driver.c:101: error: ‘struct Tcl_Interp’ has no member named ‘result’
lipo: can't figure out the architecture type of: /var/folders/15/15zQj3qeHemLNapL-foqC++++TI/-Tmp-//ccYjxRYV.out
make: *** [OBJ.i386-apple-darwin9.6.0/driver.o] Error 1
macbook-pro-15-di-sasha:v.digit sasha$Chiacchiera con i tuoi amici in tempo reale! http://it.yahoo.com/mail_it/foot/*http://it.messenger.yahoo.com
