Hi
i’m tring to build grass-svn
on osx-10.5 but
i’m having some difficoult to build it
beacouse the configure step don’t find
the opengl libtraries.
As explained in the macosx readme
i need to modify the files :
grass_trunk/include/Make/Platform.make.in
grass_trunk/configure
what i done :
in Platform.make.in changed the line 160 to :
OPENGLLIB = -dylib_file /usr/X11/lib/libGL.dylib:/usr/X11/lib/libGL.dylib -undefined dynamic_lookup
but in the file :
configure
here i’m having problems to undstand what needs a modify, i tried to replace all the :
" -lGL "
with :
" -dylib_file /usr/X11/lib/libGL.dylib:/usr/X11/lib/libGL.dylib "
or
" -/usr/X11/lib/libGL.dylib:/usr/X11/lib/libGL.dylib "
…or again :
" -/usr/X11/lib/libGL.dylib "
but the ./configure … … fail
configure: error: *** Unable to locate OpenGL library.
obviously (apologize me for these) i’m wrong to modify the configure file.
thaks a lot for your help,
Massimo.
Massimo Di Stefano wrote:
i'm tring to build grass-svn
on osx-10.5 but
i'm having some difficoult to build it
beacouse the configure step don't find
what i done :
but in the file :
configure
here i'm having problems to undstand what needs a modify, i tried to
replace all the :
" -lGL "
with :
or
....or again :
but the ./configure ... ... fail
obviously (apologize me for these) i'm wrong to modify the configure
file.
If configure can't detect OpenGL itself, use --without-opengl then
modify include/config.h and include/Make/Platform.make once configure
has finished.
what i done :
but in the file :
configure
replace all the :
" -lGL "
with :
or
....or again :
file.
You left out the "-undefined dynamic_lookup" in the replacement. And be sure to find with a "whole words" option (ie in TextWrangler/BBEdit), or it will find other things it shouldn't.
has finished.
Hmm, that's sounds like a better option than messing around with configure. (grr, I hope Apple fixes their linker soon.)
I'll look into the details that would be needed.
PS. I have a bug report for this on the GForge tracker:
http://wald.intevation.org/tracker/?func=detail&aid=536&group_id=21&atid=204
More of an informational bug, really, since it's an Apple linker problem. But if Apple can't fix it soon, a workaround in configure may be necessary.
grass-dev mailing list
grass-dev@lists.osgeo.org
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
Second Pogril: I don't know. Why IS life like sticking your head in a bucket filled with hyena offal?
First Pogril: I don't know either. Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
