[GRASS-dev] build system: module overlinking?
Dear Devs:
$ ldd r.surf.area
.. produces the list of linked libraries below.
AFAICT, this includes GDAL/OGR and all of their dependencies.
Should it not be enough for "r.surf.area" [insert any other
r.*/v.* module here] to link against the GRASS libs (plus
a handful of essential system runtime libs)?
Best,
Ben
linux-vdso.so.1
libgrass_raster.7.8.so => /opt/grass/lib/libgrass_raster.7.8.so
libgrass_gis.7.8.so => /opt/grass/lib/libgrass_gis.7.8.so
libm.so.6 => /usr/lib/libm.so.6
libc.so.6 => /usr/lib/libc.so.6
libgrass_gproj.7.8.so => /opt/grass/lib/libgrass_gproj.7.8.so
libdl.so.2 => /usr/lib/libdl.so.2
libgrass_datetime.7.8.so => /opt/grass/lib/libgrass_datetime.7.8.so
libz.so.1 => /usr/lib/libz.so.1
libbz2.so.1.0 => /usr/lib/libbz2.so.1.0
libzstd.so.1 => /usr/lib/libzstd.so.1
libpthread.so.0 => /usr/lib/libpthread.so.0
libgdal.so.26 => /usr/lib/libgdal.so.26
libproj.so.15 => /usr/lib/libproj.so.15
libcrypto.so.1.1 => /usr/lib/libcrypto.so.1.1
libpoppler.so.107 => /usr/lib/libpoppler.so.107
libjson-c.so.5 => /usr/lib/libjson-c.so.5
libfreexl.so.1 => /usr/lib/libfreexl.so.1
libgeos_c.so.1 => /usr/lib/libgeos_c.so.1
libexpat.so.1 => /usr/lib/libexpat.so.1
libxerces-c-3.2.so => /usr/lib/libxerces-c-3.2.so
libopenjp2.so.7 => /usr/lib/libopenjp2.so.7
libnetcdf.so.18 => /usr/lib/libnetcdf.so.18
libhdf5.so.200 => /usr/lib/libhdf5.so.200
libgif.so.7 => /usr/lib/libgif.so.7
libjpeg.so.8 => /usr/lib/libjpeg.so.8
libgeotiff.so.5 => /usr/lib/libgeotiff.so.5
libtiff.so.5 => /usr/lib/libtiff.so.5
libpng16.so.16 => /usr/lib/libpng16.so.16
libcfitsio.so.9 => /usr/lib/libcfitsio.so.9
libpq.so.5 => /usr/lib/libpq.so.5
librt.so.1 => /usr/lib/librt.so.1
libspatialite.so.7 => /usr/lib/libspatialite.so.7
libsqlite3.so.0 => /usr/lib/libsqlite3.so.0
libpcre.so.1 => /usr/lib/libpcre.so.1
libcurl.so.4 => /usr/lib/libcurl.so.4
libxml2.so.2 => /usr/lib/libxml2.so.2
liblzma.so.5 => /usr/lib/liblzma.so.5
libicui18n.so.68 => /usr/lib/libicui18n.so.68
libicuuc.so.68 => /usr/lib/libicuuc.so.68
libicudata.so.68 => /usr/lib/libicudata.so.68
libmariadb.so.3 => /usr/lib/libmariadb.so.3
libstdc++.so.6 => /usr/lib/libstdc++.so.6
libgcc_s.so.1 => /usr/lib/libgcc_s.so.1
libfreetype.so.6 => /usr/lib/libfreetype.so.6
libfontconfig.so.1 => /usr/lib/libfontconfig.so.1
liblcms2.so.2 => /usr/lib/liblcms2.so.2
libsmime3.so => /usr/lib/libsmime3.so
libnss3.so => /usr/lib/libnss3.so
libplc4.so => /usr/lib/libplc4.so
libnspr4.so => /usr/lib/libnspr4.so
libgeos-3.8.1.so => /usr/lib/libgeos-3.8.1.so
libnsl.so.2 => /usr/lib/libnsl.so.2
libhdf5_hl.so.200 => /usr/lib/libhdf5_hl.so.200
libsz.so.2 => /usr/lib/libsz.so.2
libmpi.so.40 => /usr/lib/openmpi/libmpi.so.40
libssl.so.1.1 => /usr/lib/libssl.so.1.1
libgssapi_krb5.so.2 => /usr/lib/libgssapi_krb5.so.2
libldap_r-2.4.so.2 => /usr/lib/libldap_r-2.4.so.2
libnghttp2.so.14 => /usr/lib/libnghttp2.so.14
libidn2.so.0 => /usr/lib/libidn2.so.0
libssh2.so.1 => /usr/lib/libssh2.so.1
libpsl.so.5 => /usr/lib/libpsl.so.5
libkrb5.so.3 => /usr/lib/libkrb5.so.3
libk5crypto.so.3 => /usr/lib/libk5crypto.so.3
libcom_err.so.2 => /usr/lib/libcom_err.so.2
libharfbuzz.so.0 => /usr/lib/libharfbuzz.so.0
libnssutil3.so => /usr/lib/libnssutil3.so
libplds4.so => /usr/lib/libplds4.so
libtirpc.so.3 => /usr/lib/libtirpc.so.3
libaec.so.0 => /usr/lib/libaec.so.0
libopen-rte.so.40 => /usr/lib/openmpi/libopen-rte.so.40
libopen-pal.so.40 => /usr/lib/openmpi/libopen-pal.so.40
libutil.so.1 => /usr/lib/libutil.so.1
libhwloc.so.15 => /usr/lib/libhwloc.so.15
libkrb5support.so.0 => /usr/lib/libkrb5support.so.0
libkeyutils.so.1 => /usr/lib/libkeyutils.so.1
libresolv.so.2 => /usr/lib/libresolv.so.2
liblber-2.4.so.2 => /usr/lib/liblber-2.4.so.2
libsasl2.so.3 => /usr/lib/libsasl2.so.3
libunistring.so.2 => /usr/lib/libunistring.so.2
libgraphite2.so.3 => /usr/lib/libgraphite2.so.3
libglib-2.0.so.0 => /usr/lib/libglib-2.0.so.0
libudev.so.1 => /usr/lib/libudev.so.1
Hi Ben,
according to manual “ldd prints the shared objects (shared libraries) required by each program or shared object specified on the command line.” In my reading not only directly linked objects, but cascading dependencies, are listed too.
On mac I can do:
otool -L bin/r.surf.area
bin/r.surf.area:
@rpath/libgrass_raster.7.9.dylib (compatibility version 7.9.0, current version 7.9.0)
@rpath/libgrass_gis.7.9.dylib (compatibility version 7.9.0, current version 7.9.0)
/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 1281.100.1)
which shows only two grass libs linked.
You may also try:
objdump -p bin/r.surf.area
which perhaps give a different result.
Nicklas
On Monday, 1 March 2021, 14:46:05 CET, Benjamin Ducke benducke@fastmail.fm wrote:
Dear Devs:
$ ldd r.surf.area
… produces the list of linked libraries below.
Should it not be enough for “r.surf.area” [insert any other
r./v. module here] to link against the GRASS libs (plus
Best,
Ben
linux-vdso.so.1
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
