[GRASS-dev] Busy SQLITE db
I'm facing the problem with Busy SQLITE db using GRASS 7.8 in a HPC system.
Reading other problems like that I saw a Metz answer [0] and another
from Luis [1] but I'm not able to fix the problem. Now the mapset is
unusable with vector.
Do you have any idea how to solve the problem and where it come from?
g.remove type=vector name=nuts2_lst_2003_daily -f
Removing vector <nuts2_lst_2003_daily>
WARNING: Busy SQLITE db, already waiting for 10 seconds...
WARNING: Busy SQLITE db, already waiting for 20 seconds...
[0] http://osgeo-org.1560.x6.nabble.com/SQLITE-db-locking-problem-td5182180.html
[1] https://gis.stackexchange.com/questions/321986/grass-what-to-do-when-the-sqlite-database-becomes-busy
ciao
Luca
www.lucadelu.org
Ciao Luca,
If you have stale processes e.g. on cluster nodes that have the DB opened this may occur.
Also the file system can have an impact (e.g. writing to an SQLite DB on a CIFS file system from Linux is simply impossible). But that should give a different error message.
So I would look for hanging processes... And you could try to copy the mapset, remove the old one and rename the copy back...
Stefan
-----Original Message-----
From: grass-dev <grass-dev-bounces@lists.osgeo.org> On Behalf Of Luca Delucchi
Sent: mandag 4. mai 2020 10:47
To: GRASS-dev <grass-dev@lists.osgeo.org>
Subject: [GRASS-dev] Busy SQLITE db
Reading other problems like that I saw a Metz answer [0] and another from Luis [1] but I'm not able to fix the problem. Now the mapset is unusable with vector.
g.remove type=vector name=nuts2_lst_2003_daily -f Removing vector <nuts2_lst_2003_daily>
ciao
Luca
www.lucadelu.org
grass-dev mailing list
https://lists.osgeo.org/mailman/listinfo/grass-dev
On Mon, 4 May 2020 at 11:18, Stefan Blumentrath
<Stefan.Blumentrath@nina.no> wrote:
Ciao Luca,
Ciao Stefan,
first time it happen---
yes, I would avoid this, but it worked
Stefan
ciao
Luca
www.lucadelu.org
Hi Luca,
On Mon, May 4, 2020 at 10:47 AM Luca Delucchi <lucadeluge@gmail.com> wrote:
Which file system do you use?
Do you use NFS by chance?
ciao,
markusN
ciao
Luca
www.lucadelu.org
Markus Neteler, PhD
https://www.mundialis.de - free data with free software
https://grass.osgeo.org
https://courses.neteler.org/blog
