Does the location wizard fails to launch for any of you in the same way it does for me, in latest releasebranch_6_4?:
Cleaning up temporary files ...
Starting GRASS ...
File "/opt/grass64-svn/etc/wxpython/gis_set.py", line 403, in OnWizard
grassdatabase = self.tgisdbase.GetValue())
File "/opt/grass64-svn/etc/wxpython/location_wizard/wizard.py", line 1791, in __init__
self.projpage = ProjectionsPage(self.wizard, self)
File "/opt/grass64-svn/etc/wxpython/location_wizard/wizard.py", line 354, in __init__
self.sizer.AddGrowableCol(3)
File "/usr/lib64/python2.7/site-packages/wx-3.0-gtk2/wx/_core.py", line 15367, in AddGrowableCol
return _core_.FlexGridSizer_AddGrowableCol(*args, **kwargs)
wx._core.PyAssertionError: C++ assertion "!m_cols || idx < (size_t)m_cols" failed at ./src/common/sizer.cpp(1980) in AddGrowableCol(): invalid column index
Received EXIT message from GUI.
GRASS is not started. Bye.
Built and running on Arch Linux x86_64.
Maciej Sieczka
http://www.sieczka.org
