I am reading the code of `r.example`. This is good code because it
explains in a clean way what is, does and why so.
Is there more such "good" code? Would you have a local copy of your C module
rich in comments, not submitted, I'd be very happy to get hands on it.
Thank you, Nikos
Nikos Alexandris <nik@nikosalexandris.net> writes:
Hi
Did you get any feedback? I will be in the same position son, and I am
also looking at good examples of modules in C and possibly python as
well?
Might be worth adding a wiki page with these examples and explanations?
Rainer
Thank you, Nikos
grass-dev mailing list
grass-dev@lists.osgeo.org
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
