Glynn Clements wrote:
Lars Ahlzen wrote:
Lines with odd widths are disproportinally common due, among other things, to the fact that many d-modules do not offer control over the width of lines in their output (and always draw 1-unit wide lines).
Actually, Cairo's default line width is 2.0 units:
http://cairographics.org/manual/cairo-cairo-t.html#cairo-set-line-width
All display modules will use this value until it's explicitly changed. The cairo driver should either explicitly change the line width to 1
at start-up, or interpret a line width of 0 as meaning 2 units rather
than 1.
Good point. It makes sense to set the default line width to 1 unit, at
the very least for PNG output, to make sure it's consistent with the
behavior of other pixel-based monitors.
Btw, how *should* a call to Line_width with a 0 be interpreted? As
"smallest possible line width" or "default line width" or something else?
There are only a handful of modules which actually change the line
width, namely d.graph, d.path and d.vect. All three modules set the
width using D_line_width() (which takes a double) and set it back
using R_line_width(0).d.vect and d.graph set the width to a user-specified value, while
d.path sets it to 2 for "bold" lines.
Interesting. So, in other words, the width of lines produced by, e.g.
the d.grid command, depends on the default line width.
Anyway, assuming that the default line width is 1 unit for pixel based
output (to be consistent), then the problem remains.
/ Lars
Lars Ahlzen
lars@ahlzen.com
Lars Ahlzen
lars@ahlzen.com
