[GRASS-dev] calculate distance with vector
hi,
I want to know what are distances between several little vectors and the big one.
so I write :
v.distance -p -a from=grille247@ventoux288 to=roland3@ventoux288 from_type=centroid to_type=boundary from_layer=1 to_layer=1 dmax=-1 upload=cat,dist table=cat,dist
the little vectors are in grille247 and they contain lots of another information.
the error is
Required parameter <column> not set:
(Column name(s) where values specified by 'upload' option will be uploaded)
how can i set the column.
thanks a lots
On 10/06/09 17:16, Quentin Page wrote:
hi,
so I write :
the error is
Just use column=cat,dist (or whatever names you want) instead of table=cat,dist. The table= parameter allows you to set the name of a table that will be created when using the -a flag to get complete distance matrices.
However, in your case, as you use the -p flag, no table will be created and results just sent to standard output. However, it still needs the column= parameter set to know how to name the output columns. I do think that v.distance could just use sensible default names (i.e. the names of the different options of the upload= parameter - with the exception of cat, which should be called to_cat to avoid naming conflicts).
Moritz
