Quentin wrote:
I want to know what are distances between several little
vectors and the big one. so I write :v.distance -p -a from=grille247@ventoux288
to=roland3@ventoux288 from_type=centroid to_type=boundary
from_layer=1 to_layer=1 dmax=-1 upload=cat,dist
table=cat,distthe little vectors are in grille247 and they contain lots
of another information.
the error is Required parameter <column> not set:
(Column name(s) where values specified by 'upload' option
will be uploaded)how can i set the column.
create a column to contain the uploaded distance with v.db.addcol.
then feed that column name to the 'v.distance column=' option.
Hamish
