[GRASS-dev] calculating bearing
Is there a simple formula to calculate bearing if you have the beginning xy of a line and the ending xy of the line?
Michael
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
trig: angle = atan(y/x) [or atan2()]
see Glynn's warnings in the archives about that going undefined at places.
see also:
  g.manual m.cogo
it gets ugly with lat/lon great circle calculations as the bearing isn't
steady. (but there are map projections that help with that)
I've got some matlab functions for doing this if m.cogo isn't your cup
of tea.
Hamish
see also:
  g.manual m.cogo
of tea.
Would you mind to add more examples to the m.cogo page?
At least I don't really understand how to use it.
I'm doing a measure tool for wxgrass at the moment and realized that I have
the xy endpoints of each segment being passed to the MeasureDist method. If
there is an easy way to do so, it seems handy to add bearing to the output
along with segment length. Do you think that it is enough of a problem with
latlon regions that I shouldn't add it in?
Michael
see also:
  g.manual m.cogo
of tea.
Hamish
phone: 480-965-6213
fax: 480-965-7671
have the xy endpoints of each segment being passed to the MeasureDist
method. If there is an easy way to do so, it seems handy to add
bearing to the output along with segment length. Do you think that it
is enough of a problem with latlon regions that I shouldn't add it in?
just skip bearing output for lat/lon locations.
this seems like a great task for trying out the Python SWIG interface to
libgis rather than reimplement algorithms in the GUI code.
see lib/gis/distance.c
    lib/gis/geodist.c
Hamish
Michael:
Hamish:
> see also:
> g.manual m.cogo
Markus:
I've never actually used it myself, sorry.
Hamish
Thanks. I've incorporated this into the measurement tool for wxgrass (for
non-latlon regions).
Michael
see also:
  g.manual m.cogo
of tea.
Hamish
phone: 480-965-6213
fax: 480-965-7671
