[GRASS-dev] call for last minute testers
Michael & myself have just applied some last minute patches to gis.m to
make it compatible with tcl/tk 8.3. As this will be released with 6.2.0
without much (any) testing, if everyone could quickly update gis.m in
their cvs (6.3 is probably fine, 6.2 branch is better- it's the same),
make, and double check that we haven't broken anything? (main toolbar
and the georectifyer canvas toolbar)
thanks a lot,
Hamish
On Tue, Oct 31, 2006 at 11:40:13PM +1300, Hamish wrote:
To help with testing, I have re-generated the CVS snapshot of 6.2:
http://grass.itc.it/grass62/source/snapshot/
as well as the 64bit binary snapshot:
http://grass.itc.it/grass62/binary/linux/snapshot/
You forgot to add time frame for testing - day? Hours?
Maris.
> Hi,
grass-dev mailing list
grass-dev@grass.itc.it
Hours, please :slight_smile:
Maris.
> > Hi,
> Markus
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
Hi
I don't know if this is related to the recent tcltk 8.3-compatibility
fixes, but there are 2 cases when the gis.m freezes, so that you have
to close it and start again to continue your work:
A:
1. add a raster
2. duplicate it ('Duplicate layer')
3. display -> error: "can't read "opt(2,1,mod)": no such element in
array" amd freeze; see the attached A.txt for details
B:
1. press 'Add postcript labels layer (using v.labels file)'
2. display -> error: "couldn't open
"/home/grassdata/spearfish60/sieczka/paint/labels/": no such file or
directory" and a freeze; see the attached B.txt for details
Maciek
(attachments)
A.txt (1.38 KB)
B.txt (1.02 KB)
unfortunately I can confirm both cases (on CVS head).
IMHO they should be added to list of known bugs, if can not be fixed in hours
(do not block 6.2.0).
Othervise I see no (new) problems in todays gis.m w tcl/tk 8.4.
Maris.
On Tuesday 31 October 2006 14:30, Maciej Sieczka wrote:
Hi
A:
1. add a raster
B:
Maciek
On Tue, 31 Oct 2006 23:40:13 +1300
Hamish <hamish_nospam@yahoo.com> wrote:
using the "clear all GPC entries" button (in the georectifyer) after setting
various GCPs only clears the first 2 columns of the first line, but the forward
and backward errors remain with following error message (command name below is
the RMS error in line 1 third col):
invalid command name "0.590568"
    while executing
"$fwd_error($gcpnum) delete 0 end"
    (procedure "GRMap::cleargcp" line 14)
    invoked from within
"GRMap::cleargcp"
    ("uplevel" body line 1)
    invoked from within
"uplevel \#0 $cmd"
    (procedure "Button::_release" line 18)
    invoked from within
"Button::_release .gcpwin.mf.topf.tb0.bbox1.b1"
    (command bound to event)
I tested with the 6.2 snapshot. Maybe someone can reproduce this?
regards,
  Otto
thanks a lot,
Hamish
    while executing
    invoked from within
"GRMap::cleargcp"
    invoked from within
"uplevel \#0 $cmd"
    invoked from within
I have submitted an updated georect.tcl from Michael to 6.2-CVS
and redone the CVS snapshot:
This should fix it (hopefully).
Time to release, we can always do 6.2.1 (even quickly) if anything
needs to be done.
Otto,
I had sent in the wrong version of a georectifier update last night. I sent
in a new one this morning to Markus, who put it into 6.2. I just added it to
6.3 a moment ago. I don't know if this fixes the problem you are having, but
you might test it. Thanks for the info.
Michale
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Date: Tue, 31 Oct 2006 14:05:13 +0100
To: <grass-dev@grass.itc.it>
Subject: Re: [GRASS-dev] call for last minute testers
forward
    while executing
    invoked from within
"GRMap::cleargcp"
    invoked from within
"uplevel \#0 $cmd"
    invoked from within
regards,
  Otto
thanks a lot,
Hamish
Not related to the TclTk 8.3 changes. The duplicate raster bug is due to
some past changes that just showed up as problematic. I put a fix into the
cvs this evening.
Michael
phone: 480-965-6213
fax: 480-965-7671
Date: Tue, 31 Oct 2006 13:30:07 +0100
To: Hamish <hamish_nospam@yahoo.com>
Cc: Michael Barton <michael.barton@asu.edu>, grass5 <grass-dev@grass.itc.it>
A:
1. add a raster
On Tue, 31 Oct 2006 12:18:38 -0700
Michael Barton <michael.barton@asu.edu> wrote:
Otto,
Hi Michael,
Thanks for the fix. I just tested it with the new snapshot from
http://grass.itc.it/grass62/source/snapshot/ but with the same error.
And another problem occurs. I am not able to create/edit a group anymore. The
second button only works for vector rectification but not for raster.
regards,
Otto
Michale
phone: 480-965-6213
fax: 480-965-7671
> From: Otto Dassau <otto.dassau@gmx.de>
>> Hi,
> Hi,
> forward
> is the RMS error in line 1 third col):
> while executing
> invoked from within
> "GRMap::cleargcp"
> invoked from within
> "uplevel \#0 $cmd"
> invoked from within
> regards,
> Otto
>> thanks a lot,
>> Hamish
On Wed, 1 Nov 2006 09:32:44 +0100
> Otto,
Hi Michael,
I also compiled grass-6.2.0.tar.gz but get the same error as with the latest
6.2 snapshot.
regards,
  Otto
regards,
Otto
> Michale
> phone: 480-965-6213
> fax: 480-965-7671
> >> Hi,
> > Hi,
setting
> > forward
below
> > while executing
> > invoked from within
> > "GRMap::cleargcp"
> > invoked from within
> > "uplevel \#0 $cmd"
> > invoked from within
> > regards,
> > Otto
> >> thanks a lot,
> >> Hamish
