I’m interested in computing a line graph for an input graph. I couldn’t find any reference to line graphs in the GRASS docs. Is there a different term I should be using in my search or a hidden function that would create such a graph?
I’ve posted this question on GIS.stackexchange as well, in case you prefer to answer there: http://gis.stackexchange.com/questions/146713/can-grass-compute-the-line-graph-representation-of-an-input-graph
Thanks and best wishes,
Anita
On 2 June 2015 at 19:46, Anita Graser <anitagraser@gmx.at> wrote:
I'm interested in computing a line graph for an input graph. I couldn't find
graph?
I don't think so, but it seems really interesting
I've posted this question on GIS.stackexchange as well, in case you prefer
to answer there:
Anita
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
Hi Anita,
For more sophisticated network analysis I tend to use igraph:
http://igraph.org/
It is quite easy to understand, well documented, efficient and supports also calculation of line graphs. It comes with both Python and R APIs.
Usually I feed graphs into it from GRASS (v.net) or PostGIS. I have not tried the new GDAL/OGR network driver...
Stefan
-----Original Message-----
From: grass-dev-bounces@lists.osgeo.org [mailto:grass-dev-bounces@lists.osgeo.org] On Behalf Of Luca Delucchi
Sent: 3. juni 2015 08:41
To: Anita Graser
Cc: GRASS-dev
Subject: Re: [GRASS-dev] Can GRASS compute the line graph representation of an input graph?
couldn't find any reference to line graphs in the GRASS docs. Is there
Anita
ciao
Luca
www.lucadelu.org
grass-dev mailing list
grass-dev@lists.osgeo.org
graph?
I don’t think so, but it seems really interesting
There is a reference on wiki:
http://grasswiki.osgeo.org/wiki/Turns_in_the_vector_network_analysis
It says that line graph is created to better handle the data with turns but I’m not sure how much of this is internal and how much is exposed in some way.
Vaclav
to answer there:
Anita
ciao
Luca
www.lucadelu.org
On 02/06/15 19:46, Anita Graser wrote:
The directest way I can see is to you the v.build option=dump output and then massage that data.
Moritz
