Ah!! So that is what the *.ige file is for.
On Mar 4, 2024, at 10:57 AM, Newcomb, Doug <doug_newcomb@fws.gov> wrote:
No,
The .ige file is what spills over after the 4GB of the .img file fills up. You need to have both.
Sent: Monday, March 4, 2024 12:12 PM
To: Newcomb, Doug <doug_newcomb@fws.gov>
Cc: Brendan <brendan.harmon@gmail.com>; GRASS users <grass-user@lists.osgeo.org>; evillasenor713 <evillasenor713@gmail.com>; GRASS developers list <grass-dev@lists.osgeo.org>
Subject: Re: [EXTERNAL] [GRASS-dev] Can GRASS import a *.ige file?
The info I downloaded for 2021 had a much more modes sized *.img file and a huge *.ige file (25 Gb or so). It looks like the best approach is to use the *.img file and discard the *.ige file. Perhaps that latter is the uncompressed one.
Michael
C. Michael Barton
Associate Director, School of Complex Adaptive Systems (https://scas.asu.edu)
Professor, School of Human Evolution & Social Change (https://shesc.asu.edu)
Director, Center for Social Dynamics & Complexity (https://complexity.asu.edu)
Arizona State University
Tempe, AZ 85287-2701
USA
Executive Director, Open Modeling Foundation (https://openmodelingfoundation.github.io)
Director, Network for Computational Modeling in Social & Ecological Sciences (https://comses.net)
personal website: http://www.public.asu.edu/~cmbarton
On Mar 4, 2024, at 7:56 AM, Newcomb, Doug <doug_newcomb@fws.gov> wrote:
Michael,
The last time I checked, the NLCD data in .img format is an uncompressed raster. You can save a massive amount of hard drive space by converting the .img files to deflate compressed geotiff, then linking via r.external.
That’s what I did for the 2019 NLCD , https://youtu.be/0NHdWSF96o0 . The 2021 is the same. The .img /ige file is 26 GB for 1 year nationwide. Converting to deflate compressed geotiff takes it down to 1.5 GB.
Hope this helps!
Doug
From: grass-dev <grass-dev-bounces@lists.osgeo.org> on behalf of Michael Barton via grass-dev <grass-dev@lists.osgeo.org>
Sent: Friday, March 1, 2024 7:00 PM
To: Brendan <brendan.harmon@gmail.com>
Cc: GRASS users <grass-user@lists.osgeo.org>; evillasenor713 <evillasenor713@gmail.com>; GRASS developers list <grass-dev@lists.osgeo.org>
Subject: [EXTERNAL] Re: [GRASS-dev] Can GRASS import a *.ige file?
This email has been received from outside of DOI - Use caution before clicking on links, opening attachments, or responding.
Thanks!
C. Michael Barton
USA
On Mar 1, 2024, at 4:43 PM, Brendan <brendan.harmon@gmail.com> wrote:
Hi Michael. As a rules file for r.category.
r.colors map=nlcd rules=landcover_colors.txt
r.category map=ncld separator=pipe rules=landcover_categories.txt
On Fri, Mar 1, 2024 at 5:39 PM Michael Barton <Michael.Barton@asu.edu> wrote:
Thanks Brendan,
Any suggestions on how to get this into the raster? Or are you thinking we should export the raster to vector and link the csv that way?
Michael
C. Michael Barton
USA
On Mar 1, 2024, at 4:08 PM, Brendan <brendan.harmon@gmail.com> wrote:
Hi Michael, I’ve attached an NLCD legend in csv format and text files with categories and color table for GRASS in case it helps.
On Fri, Mar 1, 2024 at 4:34 PM Michael Barton via grass-dev <grass-dev@lists.osgeo.org> wrote:
Thanks Ana,
I was able to do that. I’m trying to look at the NLCD. While it opens fine and is classified, there are no text labels for the landcover categories. Would these be hiding in the *.ige file?
Michael
C. Michael Barton
USA
On Mar 1, 2024, at 3:01 PM, Anna Petrášová <kratochanna@gmail.com> wrote:
There should be an .img file, try open that instead.
On Fri, Mar 1, 2024 at 4:51 PM Michael Barton via grass-dev <grass-dev@lists.osgeo.org> wrote:
It doesn’t look like r.in.gdal does this. Is there an extension or other way to import an ERDAS *.ige file?
Michael
C. Michael Barton
USA
grass-dev mailing list
https://lists.osgeo.org/mailman/listinfo/grass-dev
<nlcd_categories.txt><NLCD_landcover_legend_2018_12_17_KSy2gokzzDzRAkOmGE0z.csv><nlcd_colors.txt>
