[GRASS-dev] can not start grass82
hi sirs,
i am using freebsd 8.0 and install grass62. when i start using grass by grass62, i got this error message
% grass62
Searching for web browser, but neither konqueror, nor mozilla, opera, netscape found.
WELCOME TO GRASS Version 6.2.3 2007
  1. Have at your side all available GRASS tutorials
  2. When working on your location, the following materials
    are extremely useful:
  • A topo map of your area
  • Current catalog of available computer maps
  1. Check the GRASS webpages for feedback mailinglists and more:
    http://grass.itc.it/
    http://grass.ibiblio.edu/
Hit RETURN to continue
Starting GRASS …
Error in startup script: list element in quotes followed by “à¸à¸³” instead of space
while executing
“foreach i [exec ls -a [exec pwd]] {
if { [string compare $i “.”] != 0 && [string compare $i “…”] != 0 && [file isdirectory $i] } {
(procedure “gisSetWindow” line 244)
invoked from within
“gisSetWindow”
invoked from within
“if { [searchGISRC $gisrc_name] } {
gisSetWindow
(file “/usr/local/grass/etc/gis_set.tcl” line 903)
Error in Tcl/Tk startup. If necessary, please
report this error to the GRASS developers.
Switching to text mode now.
Hit RETURN to continue…
how to overcome this errors. many thanks in advance for any answers.
with best regards,
jotawski
มะขาม คินเดินดน
มะไฟ ฅนเหลิงฟ้า
2010/6/25 fire jotawski <jotawski@gmail.com>:
6.2.* is too old. Consider updating at least to 6.4.0RC6 [1].
Martin
[1] http://grass.osgeo.org/download/software.php#g64x
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
On Sat, Jun 26, 2010 at 3:53 AM, Martin Landa <landa.martin@gmail.com> wrote:
hi sirs,
many thanks indeed. i have just realized now that only root can run grass62 and entering graphic mode without that errors which is not quite right. i need to su to root and run grass62.
very strange .
anyway, many many thanks indeed for your hints and for your times.
with best regards,
psr
Martin
มะขาม คินเดินดน
มะไฟ ฅนเหลิงฟ้า
This is unusual and not desired. Perhaps a permission problem of the
executable flags?
