[GRASS-dev] Candidate modules for OpenMP parallelization
Hi devs,
We have a GSoC candidate who would like to do OpenMP parallelization. I could mentor, anybody else is interested?
At this point, we need to figure out (at least tentatively) which modules he could work on. After Aaron’s work in GSoC 2021, there are not that many modules left that could be described as “low hanging fruit”. Do you have any suggestions?
The proposal is due very soon.
Anna
Hi Anna,
I’m not sure if these modules are “low hanging fruit” and even fairly parallelizable, but r.stats and r.watershed might be good candidates because r.stats is generic with no output rasters, and may be used a lot in different fields, and r.watershed calculates several important hydrologic rasters that are often used as input to other modules (i.e., as a first step for most hydrologic analyses based on my experience). Maybe, r.statistics as well?
Since I now have access to HPC, I can help mentor him with some testing.
Best,
Huidae
Huidae Cho, Ph.D., GISP, /hidɛ t͡ɕo/, 조희대, 曺喜大
GRASS GIS Developer
https://idea.isnew.info/
Great you can be a mentor! Have you registered as a mentor yet? If not please ask OSGeo GSoC admins to help you with that.
Regarding the modules, I consider r.watershed as too complex for this. The student doesn’t have extensive experience with OpenMP, neither have I, so I would prefer to choose something less complex. If you feel confident it’s doable with your help, I am open to that. r.stats looks easier. What I so far suggested:
  • r.proj - Markus Metz tried it 10 years ago, it was not quite working, but perhaps we could try again with different approach, it would be an impactful module to speed up
  • r.horizon - seems doable, computes maps for different angles, so it looks like a good fit, likely some rewrite needed
  • r.texture - not as impactful, but perhaps easy when we use a similar approach Aaron used
  • v/r.surf.idw - IDW is slow, this could help a lot and it could be impactful as well.
  • r.fill.stats - it’s already pretty fast, but it could be relatively easy
The student is interested in the shorter project, so realistically, I don’t think we can do more than 3 modules.
As I said, I am definitely not an expert on this, so I would appreciate some feedback for others.
Anna
On Fri, Mar 31, 2023 at 7:24 AM Huidae Cho <grass4u@gmail.com> wrote:
Hi Anna,
Best,
Huidae
On Thu, Mar 30, 2023 at 9:42 AM Anna Petrášová <kratochanna@gmail.com> wrote:
Hi devs,
Anna
GRASS GIS Developer
