Hi
gdal-grass 1.4.3 refuses to build against GDAL 1.5.2 r14751 and GRASS 6.4 r31801.
Details:
$ $ cat /etc/ld.so.conf.d/libc.conf
# libc default configuration
/usr/local/lib
/usr/local/grass-6.4.svn/lib
/usr/local/qgis/lib
$ sudo ldconfig
$ ./configure --prefix=/usr/local --with-grass=/usr/local/grass-6.4.svn
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for ranlib... ranlib
checking for g++ -shared ... yes
checking for gdal-config... /usr/local/bin/gdal-config
using /usr/local/lib/gdalplugins as GDAL shared library autoload directory
checking for G_asprintf in -lgrass_gis... no
configure: error: --with-grass=/usr/local/grass-6.4.svn requested, but
libraries not found! Perhaps you need to set LD_LIBRARY_PATH to include
That's strange, because:
$ cd /usr/local/grass-6.4.svn/lib
$ nm libgrass_gis.so | grep G_asprintf
0000000000013da0 T G_asprintf
and
/usr/local/lib
/usr/local/qgis/lib
What could be wrong? This used to work couple of days ago.
Debian testing amd64.
Maciek
Maciej Sieczka
www.sieczka.org
6.4 r31801.
Look in config.log for the actual error message.
When configure says that a library is "not found", it means that it
couldn't link against it. There are a whole load of reasons why that
might be the case.
Glynn Clements pisze:
GRASS 6.4 r31801.
checking for G_asprintf in -lgrass_gis... no configure: error:
--with-grass=/usr/local/grass-6.4.svn requested, but libraries not
found! Perhaps you need to set LD_LIBRARY_PATH to include /usr/local/grass-6.4.svn/lib
Right.
Here's the relevant part I guess:
configure:2939: checking for G_asprintf in -lgrass_gis
configure:2969: gcc -o conftest -O2 conftest.c -lgrass_gis
-L/usr/local/grass-6.4.svn/lib -lgrass_I -lgrass_vask -lgrass_gmath
-lgrass_gis -lgrass_datetime -lgrass_gproj -lgrass_vect -lgrass_dbmibase
-lgrass_dbmiclient -lgrass_dgl -lgrass_dig2 -lgrass_rtree -lgrass_linkm
-L/usr/local/lib -lgdal >&5
/usr/bin/ld: cannot find -lgrass_I
collect2: ld returned 1 exit status
configure:2975: $? = 1
configure: failed program was:
| /* confdefs.h. */
| #define PACKAGE_NAME ""
| #define PACKAGE_TARNAME ""
| #define PACKAGE_VERSION ""
| #define PACKAGE_STRING ""
| #define PACKAGE_BUGREPORT ""
| #ifdef __cplusplus
| extern "C" void exit (int) throw ();
| #endif
| #define USE_GNUCC 1
| /* end confdefs.h. */
| /* Override any gcc2 internal prototype to avoid an error. */
| #ifdef __cplusplus
| extern "C"
| #endif
| /* We use char because int might match the return type of a gcc2
| builtin and then its argument prototype would still apply. */
| char G_asprintf ();
| int
| main ()
| G_asprintf ();
| return 0;
configure:3001: result: no
configure:3015: error: --with-grass=/usr/local/grass-6.4.svn requested,
but libraries not found! Perhaps you need to set LD_LIBRARY_PATH to
include /usr/local/grass-6.4.svn/lib?
When configure says that a library is "not found", it means that it couldn't link against it. There are a whole load of reasons why that might be the case.
Any hints?
Maciek
Maciej Sieczka
www.sieczka.org
>> GRASS 6.4 r31801.
Right.
Ah. The imagery library isn't called libgrass_I any more; it's now
called libgrass_imagery.
It was changed at the same time that I moved the clustering code to a
separate library. However, I didn't realise that it had been
back-ported to 6.4.
You can probably get around the problem by adding a symlink, e.g.:
ln -s libgrass_imagery.so /usr/local/grass-6.4.svn/lib/libgrass_I.so
On Mon, Jun 23, 2008 at 1:38 AM, Glynn Clements
>> GRASS 6.4 r31801.
Right.
back-ported to 6.4.
Obviously we cannot change a library name in 6.x as it is
hardcoded here:
http://trac.osgeo.org/gdal/browser/trunk/gdal/frmts/grass/pkg/configure.in#L126
I have reverted the name change in 6.4.svn.
Maciej, it should work again if you use 6.x.
One day, however, the plugin and GRASS 7 need a library name sync or some
condition in above indicated GDAL file.
