I Can’t add vector label and point file in cartiographic composer. But this is very much necessary in my project. I use grass6.5.
Please give me a solution.
Thanks & Rgards,
Swapan Ghosh
Thanks & Rgards,
Swapan Ghosh
On Sat, Apr 20, 2013 at 10:28 AM, SWAPAN GHOSH <swap.ghsh@gmail.com> wrote:
I Can't add vector label and point file in cartiographic composer. But this
Please see my recent answer [1] related to vector labels. With point
file you mean vector map with points? Add vector map layer -> select
map and choose data type points -> click button add -> optionally
click on properties to set the appearance of the vector map.
Anna
[1] http://lists.osgeo.org/pipermail/grass-user/2013-April/067902.html
Thanks & Rgards,
Swapan Ghosh
grass-dev mailing list
grass-dev@lists.osgeo.org
Thank you very much Anna. Please add the label to carteographic composer as soon as possible.
Swapan
On Tue, Apr 23, 2013 at 2:10 AM, Anna Kratochvílová <kratochanna@gmail.com> wrote:
is very much necessary in my project. I use grass6.5.Please see my recent answer [1] related to vector labels. With point
file you mean vector map with points? Add vector map layer → select
map and choose data type points → click button add → optionally
click on properties to set the appearance of the vector map.Anna
Thanks & Rgards,
Swapan Ghosh
soon as possible.
I just added labels support to Cartographic composer in grass 7 (Add
overlays -> Add labels)
Anna
Swapan
wrote:On Sat, Apr 20, 2013 at 10:28 AM, SWAPAN GHOSH <swap.ghsh@gmail.com>
wrote:
> Hi all,
> this
> Thanks & Rgards,
> Swapan Ghosh
On Wed, Apr 24, 2013 at 9:10 PM, Anna Kratochvílová
soon as possible.I just added labels support to Cartographic composer in grass 7 (Add
Great Anna - outstanding real-time user support, I would say
Swapan
<kratochanna@gmail.com> wrote:Hi,
overlays → Add labels)Great Anna - outstanding real-time user support, I would say
